Solved How to use the Titanium Backers with my setup?
Laserbea4k43
Voron 2.4 350
Galileo
Hi,
So I got and installed the Titanium backers on my v2.4, but only on the 2 Y-axis.
I was told it's not needed on an X-axis bar with MGN12?
I haven't been able to QGL at all since I installed them. Wondering if my current setup has something to do with that...
Should I really not use the X backer?
I'm gonna derack while I wait for a reply. Hopefully that helps.
My QGL:
11:57:42 // Average: -0.048846
11:57:42 // Actuator Positions:
// z: -0.035914 z1: -0.090315 z2: -0.039159 z3: -0.029997
11:57:42 // Gantry-relative probe points:
// 0: -0.040246 1: -0.065718 2: -0.045441 3: -0.033959
11:57:37 // Retries: 1/5 Probed points range: 0.010306 tolerance: 0.007500
11:57:37 // Making the following Z adjustments:
// stepper_z = 0.001887
// stepper_z1 = -0.006868
// stepper_z2 = -0.005744
// stepper_z3 = 0.010725
11:57:37 // Average: -0.044590
11:57:37 // Actuator Positions:
// z: -0.046477 z1: -0.037721 z2: -0.038846 z3: -0.055315
11:57:37 // Gantry-relative probe points:
// 0: -0.047167 1: -0.041027 2: -0.042808 3: -0.051333
11:57:37 // probe at 300.000,25.000,2.000 is z=1.948667
11:57:36 // probe at 300.000,275.000,2.000 is z=1.957192
11:57:35 // probe at 50.000,275.000,2.000 is z=1.958973
11:57:34 // probe at 50.000,25.000,2.038 is z=1.990451
11:57:32 // Retries: 0/5 Probed points range: 0.055146 tolerance: 0.007500
11:57:32 // Making the following Z adjustments:
// stepper_z = -0.022900
// stepper_z1 = -0.037618
// stepper_z2 = 0.001258
// stepper_z3 = 0.059261
11:57:32 // Average: -0.046694
11:57:32 // Actuator Positions:
// z: -0.023794 z1: -0.009076 z2: -0.047952 z3: -0.105955
11:57:32 // Gantry-relative probe points:
// 0: -0.039781 1: -0.025334 2: -0.052647 3: -0.080480
11:57:32 // probe at 300.000,25.000,2.000 is z=1.919520
11:57:31 // probe at 300.000,275.000,2.000 is z=1.947353
11:57:30 // probe at 50.000,275.000,2.000 is z=1.974666
11:57:29 // probe at 50.000,25.000,2.000 is z=1.960219
11:57:27 // Retries: 0/5 Probed points range: 0.046085 tolerance: 1.000000
11:57:27 // Making the following Z adjustments:
// stepper_z = 0.020876
// stepper_z1 = 0.008272
// stepper_z2 = 0.036105
// stepper_z3 = -0.065254
11:57:27 // Average: -0.059565
11:57:27 // Actuator Positions:
// z: -0.080442 z1: -0.067838 z2: -0.095671 z3: 0.005689
11:57:27 // Gantry-relative probe points:
// 0: -0.062119 1: -0.070298 2: -0.067636 3: -0.024214
11:57:27 // probe at 300.000,25.000,1.946 is z=1.921592
11:57:24 // probe at 300.000,275.000,1.973 is z=1.905670
11:57:21 // probe at 50.000,275.000,1.971 is z=1.900508
11:57:18 // probe at 50.000,25.000,1.983 is z=1.921187
Update:
De-racked and successfully ran a QGL(cold) on my first try.
I have this weird problem with Hartk's GE5C mod for the Z joints. 3 of 4 screws will fit, the last will never fully seat. It's happened on z1 and 2.
I took one of the M5x20s and cut it down to ~17mm and I can get it in completely.
Please let me know your thoughts on keeping the X backer uninstalled.
Update:
Which lower belt clamps did you use...the ge5c mod uses thinner clamps and a lot of people forget to use them ...they should help with that if you used stock ones
Hey there.
I did use the ones that come with your mod. They are more thin than the ones on the top of my z-joints.
Ok do you have a picture and did you use the m5 washer/shim on top?
was having problems, so I took all of the washers off. If you really recommend I use them, I will put them back on.
I need to re-bolt anyway, because I didn't do it while the gantry was hot.
-edit-
My washers are only flat on one side. Will that cause a problem? They do measure at about .9mm thick.
-edit-
The washers are what take up the extra space and if you removed them it's why you had to cut the bolt down..you should put them back 👍🏼
Yeah I started to see that after I replied to you :ROFLMAO:. Thanks for clarifying :)
I’ll put them back before I heat up and tighten tomorrow.
