If you had to build another Voron?
MichaelOToole
Because I was forced to tinker with my Voron 2.4 after almost 2 years, I am half tempted to build another one.
Which leads me to ask: Which Voron would you build and what would you include?
For my part I'm leaning towards another 2.4 (350mm version) with: Stealthburner, Tap, Canbus\USB etc., (and possibly All Metal again, although it's expensive).
It would be interesting to know what you guys would build allowing for your experiences?
Well, since I started with a Trident and added a V0.2, a V2.4 is the obvious next move for me. Not sure if I'd go with another 250 or move to 300. I might tinker with one of the popular non-Stealthburner tool heads and the Beacon probe though I've been happy with the Stealthburner/Tap combo on the Trident. I'd almost certainly stick with Revo since that's what I have on all my printers now. Being a fourth FDM printer for me, I might try Canbus.
Don't!
I built my first 2.4 a couple years back. Now I have two 2.4s....and:
Two more 2.4s in boxes, a RatRig ready to put together, four VzBots (I already had 2 TronXYs), two more vzeroes to build, a Doron, and a Micron kit on the way.
But since that 2.4...I've also built a Switchwire, four MKS clones, three Vzeroes, LH Stinger, converted a couple cartesians to something better.
And that doesn't include all the pre-built printers I own.
It's a slippery slope...but if you have your indulgences in check you may be better off than I am. I go overboard when I find something I like to do.
@claudermilk
Have to admit I really like stealthburner/tap combo and Revo is my number one choice (even if a bit expensive). I might consider trying Beacon in the future.
No matter what I choose, Canbus is a must for me. The EBB SB2209 CAN (RP2040) has worked really well but I might try the Nighthawk option (as I have one, it might be worth checking out at least).
@5twenty
You have a lot of printers and yes you went overboard ;) but I totally understand, I have four other printers (all Creality) and even one I designed myself.
Using and then improving/modding them, wasn't work, it was a genuine pleasure... I loved every minute of it.
I still curious as to what the other guys would say...
It was for me as well. If I could build them forever I would.
I wasn't trying to discourage you, sarcastic attempt at the opposite...do it. Build a vzero...a tiny challenge that is a joy to watch in action. Tons of mods you can incorporate there as well.
I'll duck out and let others contribute, good luck.
Anyone use the Nitehawk, would love some feedback...
@NoGuru, you switched to Nitehawk and if I remember correctly, you were pretty happy with it, just checking to see if you had any issues since.
I'd be in the same boat except I have space limitations. Heck, I have an Elegoo Saturn 4 Ultra sitting in a corner because I haven't cleared space to set it up safely yet.
Hey sorry, I am not on as much these days. I do think I have the Nighthawk on my 350. Pretty good board once I got it working. think I had a few minor snags with it but no issues in the last year with it.
I moved through cruelity, twice, before getting my V2.4 350. I changed to all metal pretty fast and I did away with the clockwork that it came with. It never worked well tbh and cooling was also a bit iffy at times. But I used my revo micro, which I had used for a long time before this point, and almost instantly hit the roof with its extrusion limit. now I use a phaetus rapido2 uhf and I use a cartographer, all on canbus.
I asked myself the same question a while ago and I made my choice after I realised I needed a printer to do small fast things. 80% (yest that is a guess and a blind wild stab in the dark) is small stuff anyway, so I got myself the zero.
Everytime I look at the box it came in I smile, because I know that one day I will build it and I will be able to do small things fast :p
Looks like chaoticlab can supply all my needs in individual kits, for example, I just ordered: Set 4: Voron 2.4 Heated Bed Kit (350mm) for $129 and strangely enough, shipping was free?
I suspect the price does not include duty or VAT but even so, being able to order individual kits changes things as I have lots of spare parts.
  • Set 1: Voron 2.4 Electronics Kit
  • Set 2: Voron 2.4 Full Cable Kit ()
  • Set 3: Voron 2.4 Full Fastener Kit
  • Set 4: Voron 2.4 Heated Bed
  • Set 5: Voron 2.4 Motion Kit
  • Set 6: Voron 2.4 Panels Kit
  • Set 7: Voron 2.4 Frame Kit
Have a look here
There's something nice about buying individual kits over time and pretending I'm not spending money :)
Next, Set 7: Voron 2.4 Frame Kit...
Have a look here
Pretend you are not spending money….. I am taking notes cause I must learn how to do this.
I also need to teach my wife to see it this way.
I am hoping volume two of this thread will elaborate on that 😬
