Issue with LED Strip on Manta m8p
albion
I'm running: BTT Manta m8p+CB1 - Klipper - Mainsail
printer.cfg:
[neopixel Case_Light]
pin: PC6
chain_count: 143
color_order: GRB
initial_RED: 1.0
initial_BLUE: 1.0
initial_GREEN: 1.0
The strip has 143 chips (about a meter in length) and I am using the Manta RGB port. Using the above configuration after a restart of the printer the entire strip lights up perfectly in white (It works for whatever color I try).
But...
SET_LED LED=Case_Light RED=1 GREEN=0 BLUE=0
When I run the above gcode only about the first 60 or so LEDs change red, the rest stay white.
I tested using 0 0 0 INDEX=10, INDEX=20 to 100. There should be 10 unlit LEDs on the strip. There are only 5.
I'm not sure it's a power issue, the initial startup wouldn't light the whole strip, right?
Is there a hidden chain_count equivalent in the SET_LED command?
Am I missing something here?
Any help would be appreciated. Thanks.
-Craig
