Klicky PCB Probe = not responding to click
hendr1x
V2.4
Hello everyone,
I'm running a Klicky PCB Board with Stealthburner/Hartk's 2 piece PCB on a Octopus 1.1
With config [probe] pin: PG15 = always triggered, ~!PG15 + !PG15 = always open.
When I attach the probe the LED light on the board comes on. I tested continuity from the octopus (PG15) to BAT85. I also confirmed ground from Probe pin to octopus common ground. No idea what to do here. Any ideas?
I wired in the klick directly to the J34 port (same PG15 pin) and it worked fine. I think that means the issue has to be something to do with the Stealthburner PCB but I have no idea what it could be. Any ideas for tests I could run?
