Klipper Bed Mesh at Max Height, nozzle prints 2mm above bed...
evo_grind
Voron 2.4 r2 300mm
I added the section to my printer.cfg file using the guide from the klipper docs: https://www.klipper3d.org/Bed_Mesh.html
I am still using the recommended omron sensor and perforam a home -> QGL before bed meshing.
[bed_mesh]
speed: 180
horizontal_move_z: 5
mesh_min: 30, 30
mesh_max: 270, 270
probe_count: 3, 3
Whenever I run a bed mesh calibrate, it saves a mesh that is way too high (see image below), at the maximum of 2mm, and if I try to print with that, the hotend starts printing 2mm above the surface...
How do I fix this?
