LDO Nitehawk toolboard with Galileo 2 extruder.
FriedPCB
Hi. I'm upgrading my V24 with LDO's nighthawk toolboard. I'm using a Galileo 2 extruder with stealthburner. I downloaded the cable chain anchor from LDOs nitehawk website. I'm at a complete loss on how and where to mount the anchor on the Galileo 2. Is there a mod to the Galileo to accommodate this anchor? What am I missing? Any help would be appreciated. I posted this on Discord as well. Thanks.
The g2 has it's own anchor chain mount that you use. The ldo one is for clockwork 2
Is there chain mount for the G2 that is specifically designed for the nitehawk toolboard? The standard chain mount for the G2 in my opinion is too high relative to where the cable exits the tool board. Using the standard G2 chain mount would force too sharp a bend on the harness wire.
Hello, sorry to for commenting old thread but i also have similar problem. Is there a STL file somewhere, what you could print and use to secure the usb-cable to the toolhead for Nitehawk-SB and Galileo 2 for Stealthburner ?
Hi. I never found one. I ended up using the standard chain mount. It's a tight bend but it works. I have had no issues.
Currently this seems like ok solution to secure usb-cable connector to the toolhead. The cable is attached to the printed strain relief part with cable ties.
