You asked for it...
I have something set up for just about every function the printer does. I have SB with Rainbow Barf in the logo and 18-led case light strips on each side wired in series for an overall 36 lED strip in the case.
Thanks, that's a nice set of macros. I was hoping that somebody did the heavy lifting to re-write the stealthburner status macro.
I'm getting consistency issues with the LEDs. It's basically random, but what I get:
works fine
Doesn't turn on or off
random colors
fading intensity to end of string.
one green or purple led at the end (or in the middle... with the rest of the string dark)
I'm thinking that there's some noise in the signal wire or the power. I've read else ware that putting in a 100uF cap (with appropriate voltage rating) will help damp out the noise.
Thoughts?
(might not help that I'm using the el-cheapo string of LEDs off amazon.)
When I did my recent re-wire/upgrade I ran into the same LED issues as others. I added the 2-piece hartk toolhead PCBs, LDO breakout at the other end and the Rainbow Barf SB logo. I was getting the incorrect colors in the toolhead like others . I added a 200 ohm resistor (IIRC) right at the controller end of the signal wire. Problem cleared up after that.
