Mod name | Mod author | Link to the mod |
Voron 0.2 Tophat extender | Meningitix |
Printables
www.printables.com
VORON 0.2 Carrying handles | Artxime |
Printables
www.printables.com
Matchstick Diffuser | Maple Leaf Makers |
GitHub - MapleLeafMakers/Matchstick_Diffuser: Diffusers for Matchstick led stripsDiffusers for Matchstick led strips. Contribute to MapleLeafMakers/Matchstick_Diffuser development by creating an account on GitHub.
github.com
V0 Stealth Bumper | Maple Leaf Makers |
GitHub - MapleLeafMakers/Stealth_Bed_FrontContribute to MapleLeafMakers/Stealth_Bed_Front development by creating an account on GitHub.
github.com
Kirigami Bed | ChristophMuellerOrg |
GitHub - christophmuellerorg/voron_0_kirigami_bedContribute to christophmuellerorg/voron_0_kirigami_bed development by creating an account on GitHub.
github.com
Kirigami Wago Mount | ChristophMuellerOrg |
voron_0_kirigami_bed/CAD at master · christophmuellerorg/voron_0_kirigami_bedContribute to christophmuellerorg/voron_0_kirigami_bed development by creating an account on GitHub.
github.com
Screwed Front Door Hinge | xbst_ |
Screwed Front Door Hinge by xbst_Mod to screw the front door panel (instead of VHB)
mods.vorondesign.com
V0 1515 T-nut | Zen3D |
V0 1515 extrusion slot cover | nhchiu |
Printables
www.printables.com
Mod name | Mod author | Modification done | Link to the mod |
Voron V0 Hinged Rear Panel Hex Mesh | Hr_Ravn | Cut out a bit of the top left corner to route cables for the leds in the top hat |
Printables
www.printables.com
V0 Chamber Thermistor Mount | Maple Leaf Makers | I changed the rotation of the chamber thermistor mount so it can be used on top of a horizontal extrusion instead of a vertical one (and the logo is still displayed correctly). |
Printables
www.printables.com
Voron Cable Clamp Umbilical mod CANbus | Ślimak | Made it smaller as my CANbus cable has a smaller diameter |
Printables
www.printables.com
Guile mini RSCS fan for Voron V0.2 | thrutheframe | Adapted to the fans I used (EBM Pabst radial fan 3D-EL-FAN-RA-RLF-24) |
Printables
www.printables.com
V0 MidPanel HexPattern | Zen3D | Adapted for different print orientation, removed the voron logo on the top left and adapted for my mod of the nevermore filter. |
V0 MidPanel HexPattern by Zen3DVoron0 MidPanel with Hex pattern and Wire cover
Voron0 MGN9C X Axis | hartk1213 | Adapted for my Mini Stealth Burner bowden toolhead mod. |
Voron0 MGN9C X Axis by hartk1213This mod, replaces the stock MGN7H for MGN9C on the V0
V0.2 MGN9C X Axis | ruiqimao | Used the A/B drive frames and added the y endstop again. |
Mod name | Description | Based on | Link to the mod |
Electronics compartment side covers | A cover to hide the sides of the electronics compartments. I combined the idea from Maple Leaf Makers for a side cover for the electronics compartment with the mid panel hex pattern from Zen3D to have a seamless look. |
Printables
www.printables.com
Deck panel cover | A cover for the deck panel. It is placed on top of the normal deck panel and is purely aesthetic. |
Printables
www.printables.com
Tophat led mounts | Led mount for led strips that lights the V0.2 from the top of the Tophat. |
| not yet published |
Hex pattern top hat extender panels | Custom hex pattern panels for an extended tophat. | - |
Printables
www.printables.com
Electronics bay cover + umbilical guide | Custom electronics bay cover to route the bowden tube, toolhead umbilical and two led cables for the left and right led strips. |
Printables
www.printables.com
Braided cable guides for 1515 extrusions | Guides for the braided led and fan cables to route the cables neatly. They are desiged based on the mount of the matchstick diffusor by Maple Leaf Makers |
Printables
www.printables.com
Piggyback air filter mod | A Nevermore/MF Nano inspired air filter that is located in the back of the printer (electronics compartment) and draws air in through one side of the mid panel and pushes it back on the other side. The filter cartridge can be changed easily from the back of the printer. |
| not yet published |
Tall skirts mod | Taller skirts that are based on the V2.4 / Triden skirts. They allow the 4.3" touchscreen to be mounted in a compfortable position and allow for a vertical mount of the raspberry pi in the bottom electronics compartment. |
Printables
www.printables.com
Bottom electronics compartment mod | Together with the tall skirts mod this mod adds a grid of m3 hex nuts to the bottom of the printer. On this grid the electronic components can be mounted flexibly. The mod includes mounts for the RaspberryPi, BTT U2C, BTT SKR Pico, Wagos and standoffs for custom cable management. | - | not yet publsihed |
Bottom panel mod for better air circulation | A more open bottom panel that allows for a better airflow. |
| Included in the tall skirts mod:Printables
www.printables.com
Mini Stealth Burner bowden mod with BTT EBB36 mount | Modified Mini Stealth Burner bowden toolhead to attach a BTT EBB36 to it to use canbus with a bowden setup. |
| not yet published |
Upper rear panel with Voron logo | Printable upper rear panel with Voron logo. | - |
Printables
www.printables.com
Top hat corner cable guides | A cover that can be mounted into the corners of the top hat that hide the cables for the leds in the top hat. | - | not yet published |
Thanks. I used a BTT U2C and a BTT EBB36 and a self made cable.Very nice post and pictures.
What canbus setup did you use?
Thanks a lot! Did you already see the BuildLog on Discord? https://discord.com/channels/460117602945990666/1224057511246827665what a work of art.
voron zero razer edition.
can you please share a video or pictures of side , top , electronics chamber, airflow etc..
Checked just now. It's packed with a lot of info will go through it slowly.Thanks a lot! Did you already see the BuildLog on Discord? https://discord.com/channels/460117602945990666/1224057511246827665
Just uploaded the tall skirts mod yesterday - https://www.printables.com/model/841565-tall-skirts-mod-for-voron-02anything new?? Looks great, looking to use some of your ideas in my V0.2
