AverageMaker69
Hello,
I just recently built a Voron Trident. After successfully installing klipper with mainsail everything was working perfect up until about a few weeks ago when I refreshed mainsail to do some updates. After updating and restarting my printer and mainsail with everything still working just fine the next day when I go to turn on my printer it can no longer connect to the mcu anymore.
After looking online for the fix most suggestions were to change the usb bus speed but some we’re saying to change it different speeds then others and not knowing or understanding how to do this and afraid I would probably mess something up I decided to just back up my printer.cfg and reinstall klipper.
After doing so everything worked perfect again for a week as before up until I refreshed and updated mainsail again. The same exact thing happened. My printer was working perfect after updating then the next day it could not find the mcu to connect.
Once more I reinstalled klipper on the pi updated everything in mainsail but now I’m currently having issues with the octopus v1.1 board.
After putting in the firmware.bin sd card and running
ls /dev/serial/by-id/*
It’s says
ls: cannot access no such file
To sum everything up
I replaced the usb cable , re did the klipper installation to make sure I set everything up correctly making sure the winscp file was named firmware.bin and the sd card was formatted to fat 32 .
I ran dmesg and it appears there is a usb connection with no errors.
I noticed the blue light did not blink or is not blinking on the octo board so it makes me think I bricked it or for some reason it’s not reading the firmware.bin.
Anyone else have this problem? Any tips or suggestions? I’m not to thrilled if I have to buy a new board just to deal with the same issues when doing mainsail updates. What would cause this issue in the first place?
I saw that I could possibly re install a new bootloader onto the boards chip but I would have to buy a special connector and something to do with jumping boot 0 pins to the octopus but I’m not sure if I’m smart enough to figure all of this out.
It’s says
