Solved Save & Restart No longer works
Laserbea4k43
Hello,
When editing my config files and needing to restart klipper or firmware, klipper seems not to be able to connect.
I always have to restart my pi in order to get things working again.
I've attached logs, if anyone can help me out, thanks.
Thanks guys,
I didn't realize i'd gotten replies!
It turns out I accidentally commented out a line in the printer.cfg
Actually it didn't work.
I thought it did, I was wrong.
I'm using an RPi 4 B and BTT Octopus Pro with Fluidd
I've been having a simiilar issue for a few weeks. I don't remember the exact message, but it is something like "can't connect to MCU". The issue doesn't happen every time I save and restart, but it does happen the majority of the time. The only way to restore operations is a full restart of the Raspberry PI. I have a suspicion that a recent update to Moonraker or Klipper may be part of the problem. I've searched Discord for the error message and there seem to be a few people there with similar issues -- mostly beginning in December.
In the voron discord, the first pinned message in #klipper solved the problem for me(thanks @Dragonkitty)
sudo systemctl disable ModemManager.service then reboot the pi.
Apparently, there are conflicts with klipperScreen.
I’ve been hitting save & restart for fun 😁
That fixed my issues! Thanks again!
BTW, on the KlipperScreen GitHub, they are now recommending using command sudo systemctl mask ModemManager.service as a more "persistent" solution.
Proabably a little bit beyond my understanding, but I'm guessing the masking, which seems to do a redirect, will prohibit the re-enablement of the service during updates/upgrades.
Correct. It will prevent re-enabling by another process or update.
I have the same problem, but the suggested fix didnt work. What else could it be?
Hardware would be Pi5 and Octopus Max EZ.
I can provide more information if needed.
Hello,
I know this might sound weird, but either put tape on your 5 V pin on the USB cable that goes from the pi to the main board. Or get yourself a USB power lifter. I put these on all of my machines. I’ve had several instances where power between the pi and the main board have created some strange issues.
Ik reached out tot ldo Yesterday . And they could tel me it is possible due to thé v1.5 USB adapter . So i Puttet now they v1.4 back on it . And Will see when it out back thé v 1.5.2 Nhk board how it Will Respond .
