I'm trying to make V0.1 print, the only movement that it can make is diagonal; STEPPER_BUZZ STEPPER=stepper_x and STEPPER_BUZZ STEPPER=stepper_y works properly. What could be the reason?
If not that then it means that only one motor is doing the work. Check your belt path and make sure the the belt is not touching any plastic parts. If it is, it's not routed properly. Once you've checked what Sanity has asked and checked the belt path, it's a matter of checking the motor configuration in your klipper config and that your wiring is correct.
