Stealthburner Nozzle LED Turned Off During Longer Print
JBryant
I'm running my first longer print on my newly assembled LDO V2.4 and until now the SB Leds were behaving as intended with colors changing based on STATUS lines in my Macros. Today, roughly 2 hours into a 4 hour print, the nozzle leds turned off, they should be white while printing. I was able to turn them on via mainsail but it also set the logo led to white.
Any thoughts why they turn off ok their own?
Do you have an LED in the center logo area and did that turn off? I have never heard of this happening.
The logo led stayed red as commanded in my macros but the nozzle leds turned off. I looked in the console and there were no explicit calls to turn off the led but I didn't check any logs.
Neopixels supplied with my LDO kit did the same. They were pretty flaky timing wise. Replaced them and all good now.
Update, I was just running a 5 hour print and happened to be in the room when the neopixels turned off around 2 hours in. I issued the nozzle led off macro and the nozzle led on macro and they turned on for about 10 seconds and went black again. The chamber is at 56C. I wonder if these kit supplied ones can't take the heat? Are there known "good" ones I can replace them with?
