Switchwire variant?
120decibell
Administrator
Staff member
Moderator
Voron Owner
Is anyone running the Klicky for Switchwire? How do you like it? Does the servo arm work well?
jtdowney
I run Klicky on my Switchwire. The servo is ~fine. It was pretty finicky to get started, but I also have the cheapest servos from Amazon, so I am not sure if that is a problem. After a break-in and tuning period, it works great for me and has helped meshing quite a bit because of the built-in magnets on the MK52 heat beds.
cpu_overclocker
I have found a method how the original probe is giving me good enough result to not make the switch to clicky.
I have a 4x4 mesh and a 3time retry with 0.02 tolerance and the silicon mod and i have the bed everytime flatter than 0.110
jtdowney
The reason I switched is because of the temperature drift I was getting with the probe. I use my switchwire for PLA with no enclosure and it would drift in Z between prints quite often.
