Tap signal voltage between 24V and 6V
Michel
Hi,
first built for me,
I am setting up aV2.4 with TAP. from Formbot
I am not able to see it trigger on mainsail command line but the led change color from red to blue.
I did check the signal wire and it does not go to 0 volt. is this ok to go from 24V to 6v ?
I guess this is why Kilpper does not see it trigger.
If that is the case, how this can be resolved ?
Can I put a resistor between the ground and signal wire to pull down the residual 6V ?
Thanks
