V0 conversion to use 2020 profile
Sunb
Hello guys,
I am planing to rebuild my V0 using 2020 profile. Using small profile with preloaded nuts just kill my patience. Thank you!
JosAr
Staff member
Moderator
Voron Owner
Be advised, Tiny-M on it's current configuration needs 5mm 2020 extrusions, and those suffer from the same issue as V0 there is no post insert nuts.
I would go to Tiny-T or other design that uses 6mm 2020 extrusions.
Sanity Agathion
Staff member
Moderator
Voron Owner
I have 5 mm profiles I bought initially for Legacy before I obtained Funssor frame. Those T-nuts from VonWange can slide right in. You can also buy - usually - at a seller who sold you extrusions - but they are usually even more eye-watering expensive than Misumi t-nuts.
JosAr
Staff member
Moderator
Voron Owner
It did not enter in my equation, but factually, you are correct, they do exist, like you say, they are very expensive in our quantities and very had to find from other sources (like aliexpress).
