V2.4 with some 2040 size extrusion.
ChrisA
If nothing else, I think this looks better. The frame is also twice as stiff and there is more room and possibly better cooling for the electronics and some more room for a CAN cable on top. None of the printed parts are modified.
I want to try closed-loop motors with a 36 or 48-volt power supply. More room on the bottom is good, and as said, I think it looks better. What do you all think?
Next, I want to address the problem of a TAP-modified Stealthburner hitting the front doors. I think I should move the doors about 10mm forward. This will require changes to the side extrusions and side skirts to make them 10mm longer. The gantry would remain unchanged.
Great looking build!
I have some 2040 in stock from a previous project that I'd like to utilize so this is great.
Is it just the 8 horizontals that are 2040?
What else was changed in terms of the extrusions? The uprights extended 40mm to leave the same print volume as the "original"?
Thanks!
