ChrisA
If nothing else, I think this looks better. The frame is also twice as stiff and there is more room and possibly better cooling for the electronics and some more room for a CAN cable on top. None of the printed parts are modified.
I want to try closed-loop motors with a 36 or 48-volt power supply. More room on the bottom is good, and as said, I think it looks better. What do you all think?
Next, I want to address the problem of a TAP-modified Stealthburner hitting the front doors. I think I should move the doors about 10mm forward. This will require changes to the side extrusions and side skirts to make them 10mm longer. The gantry would remain unchanged.
