What have I done wrong
Do you have any idea as to what is wrong? I am currently inclined to completly rebuild the printer.cfg file.
I really want to see a screenshot of the console where you're running the command, and getting nothing in response, because that's just...not how it works.
I wrote an earlier reply but apparently the forum software did not post the reply.
Do you have any thoughts on what might be wrong?
I am inclined to remake the printer.cfg file and see if that helps.
Alright. So. The expected result there is Open for both, until you actually try to home.
So we need to figure out why that's not happening and...I'm embarrassed to admit, I seem to have missed the obvious in your log, days ago.
[stepper_x]
endstop_pin = PC15
and no diag pin setup at all
endstop_pin should be pointing at the virtual endstop, and the diag pin, well, should be configured.
see https://docs.vorondesign.com/tuning/sensorless.html
Stucarius, have you set up sensorless homing (shiftingtech links to the instruction for this)?
Only then you get X/Y without endstops (the stepperdrivers become your endstop..sorta).
The eddy probe only senses in z-direction and cannot detect the X/Y dimensions....
I thought I set up sensorless for all end stops but I gave up on that and went ahead with Eddy for Z endstop and physical triggers for X and Y. When I turn on the machine and boot up Klipper I am still getting X:triggered Y:triggered Z:open.....Whats up?
Try putting a caret on the endstop_pin on X and Y steppers:
endstop_pin: PC15 > endstop_pin: ^PC15 on X
and
endstop_pin: PD7 > endstop_pin: ^PD7
then query again, and let us know what it says.
I thought I set up sensorless for all end stops but I gave up on that and went ahead with Eddy for Z endstop and physical triggers for X and Y. When I turn on the machine and boot up Klipper I am still getting X:triggered Y:triggered Z:eek:pen.....Whats up?
did you remove the relevent DIAG jumpers when you switched back to wired? Did you check that the two endstop_pins match the ports you have your endstops actually plugged in to?
I don’t have physical endstops. I’m using the Eddy for that. Could that be the problem?
As was mentioned before, the eddy current sensor is only for the z axis. For x and y you need another solution. You can have switches OR you can use sensorless homing. But either way it needs to be setup and defined properly. What do you think you are using for x and y homing?
Eddy is just for z axis. Endstops forn x and y requiers jumpers on the board (x and y) and doing a calibration procedure that is kindoff well documented
