What wire lengths do I need for my V2 or Trident?
Takuya
Moderator
Voron Owner
As this gets asked quite a lot, I figued it would be a good idea to also incooperate the wire lengths for different printers into the forums.
Please keep in mind that these charts only include what goes into the cable chains to the gantry and it does not include the exhaust fan or any other wiring at or below the bed.
Trident Gantry Wires​
Lengths​
Chain250x250x250300x300x250350x350x250
X (Toolhead)190cm200cm210cm
Y (Endstop Pod)160cm165cm170cm
Z (Bed)100cm100cm100cm
Wire Counts​
ChainSignal24AWG20 AWG
XHot End Heater2
XThermistor2
XExtruder Motor4
XInductive Probe3
XHot End Fan2
XPart Fan2
YX Endstop2
YY Endstop2
ZGround1
ZBed Heater2
ZBed Thermistor2
ZZ Endstop2
V2 Gantry Wires​
Lengths​
Chain250^3300^3350^3
X (Toolhead)270cm285cm300cm
Y (Endstop pod)205cm215cm225cm
Z (AB Motors)150cm155cm160cm
Wire Counts​
XHot End Heater 2
XThermistor2
XExtruder Motor4
XInductive Probe3
XHot End Fan2
XPart Fan2
YX Endstop2
YY Endstop2
ZA Motor4
ZB Motor4
If you're a real cheapskate, cut a couple of wires to the specified lengths, run them and get an idea of how much you can shorten them (or how much more you need). You need to have your final placement of your electronics worked out though. Don't decide on minimum length wires then up and move your controller board to the far corner of the electronics bay!
