m00dawg
- Voron 2.4
- Clockwork 2
A wire broke on the extruder cable chain that goes to my extruder motor. Thank goodness it was right there up front. Not sure how it happened though as it's in a place I wouldn't expect to see a lot of stress. In any case, I would guess the proper answer is to order a new wire bundle but for the meantime, is there a recommended method of doing a field repair so I can get back to printing while that's on order?
I can just solder it and use heat shrink or electrical tape but I also have those heatshrink/solder combos you can use with a heat gun. I'm just worried either of those options would cause the wire to rub against other wires and cause further failures.
