RocknRolla
I needed to replace the connector on a PT1000 recently from a Formbot Kit. I assume because of the temperatures, it has a fiberous cloth-like jacket with an outer laquer-like shell. Super PITA to strip, and the best I could do left the end of the jacket frayed in a way that seemed negative for the end crimping.
I tried a razor but found the super thin wires made this really sketchy.
I tried a high end pinch and pull type wire stripper that works beautifully on most normal wired, but it just slides off.
I tried two different admittedly cheap plier/scissor type wire strippers. They worked very poorly... Basically just frayed the ends.
I tried a powered hot knife wire stripper made for industrial use, but the fibers in the jacket have a higher melt temp than the stripper.
I tried wrapping the wire with tape first, but didn't really work because tape doesn't stick to this wire.
I tried heat-shrinking before stripping. This helped and is what I ended up using. But it was still far from ideal.
Is there a special tool for this? Will a top quality Japanese, German or USA made pliers-type wire stripper work well, or will that still be a pain?
Thanks in advance for any tips.
