CautiousLeopard
You likely still have not configured your movement in the correct directions, as well as the end stops positions in your config.
You say X can home, and also when homing everything the tool head moves to the right, and triggers the x switch ? If your x does move to the right to home (which is normal) then your end stop position for X needs to be the max position - you still have it configured as 0. The sample config doesn't have it at 0. This is presumably a change you are making?
Your printer thinks the right side is 0, not x max. Likely you have x and z directions inverted.
You've done a lot of configuration changes recently, the first thing you should do is re-visit https://docs.vorondesign.com/build/startup/#stepper-motor-check and re-run these checks that the steppers turn in the correct directions. I know you said you read this before, but lets do it again, re-read, and re-test the stepper buzz instructions, noting the movement the steppers make.
