Abandoned.
Questions to anyone with actual knowledge of the outcome.
1. Using mgn12 rails for the rear Z instead of mgn9? pros? cons? anything?
2. Using old linear rails for backers on Y axis instead of purchasing flat expensive titanium, has anyone tried it? I have a titanium one frim my old x gantry already and dont want the extra weight of all other rail.
3. Wobble X ? Ive read that it works but would you build it first or wait to see if its needed, I believe you lose some Z but honestly with the extra 50mm im building into this and rarely ever using the 250ish available on my trident Im not worried about 18 some odd mm of loss if its worth it.
4. Nitehawk rev C , Im pretty sure this is the route im going since can is more of a cant with the chamber temps this will be running. My trident has canbus and despite hours and hours of printing with a chamber temp of 65-70c I’ve had zero issues and even the setup went off without an hitch, that said I’ve read about all the problems. I was going to go straight umbilical until I started researching parts and realized they finally released the nitehawk in the ebb36! The biggest plus for me besides the easier install is the loss of the extra cable for the beacon , that alone makes it worth it. Any practical advice would be greatly appreciated.
5. Power supply configuration, im pretty much leaning towards 48v, maybe, that said if I do go that route does that mean I can get away with the smaller 24v meanwell therby using the same space as one 200w 24v for both supplies , the electronics is the part I’m most apprehensive about and the wiring , I can only do monkey see monkey do since I don’t have alot of practical application
6. 5v ps or no? Is pulling from the board a bad idea ? Is it better to be able to power up the pi while not the entire printer , that seems like a good idea.
7. Octopus Pro, I know there are three chipsets and of that two are favored , at the time I’m writing this one is unavailable , do I need the one I can’t get , will I kick myself for not waiting?
Thanks to anyone taking time to leave some advice, I have discord as well and will be most likely posting in desperation once the Monolith awd gets underway, that one I have zero knowledge other than what I’ve read and no instructions . Awesome
MGN12 vs MGN9: MGN12’s a bit beefier, so if you’re hauling some serious weight on the Z-axis, go for it. Otherwise, MGN9 should be fine.
Old Rails for Y: If your old rails still run smooth, why not reuse them? Could save some cash, just don’t expect titanium-level precision.
Wobble X: If it ain't broke, don’t fix it. If you see wobble, then maybe consider it, but you’re good for now.
I just replaced my x axis mgn9 (2 pieces) for one mgn15 real hiwin, this is on my current V2.4 with chaoticlab cnc parts.
Reasons are the mgn9 were horrible and caused nearly 1mm of wobble on a single rail. The second rail just served as a steady and this is stupid imho.
It is way more difficult to line up two rails to run smooth together then to make one perfectly true and parallel to the bed. Also my mgn was having tough spots where the fixing screws were. It must have deformed in those places.
So my conclusion is, and has been for years, beter spend a buck or two more for reliability and get a simple setup in return. Today I buy nothing but real hiwin and nothing smaller then mgn15. That is until I might build the voron 0.
I have in fact built bed slingers with standard hiwin 15 rails with full sized carriage blocks. This meant I did not really need an extruded profile for the x axis anymore and the rails became load bearing.
Interesting. Got an pics of how you supported this?
I cannot do photos because I am nowhere near that printer. But I have my 3d designs.
In the front view you can see the frame for both the rail and the ball screw. That frame is only 3 mm thin so it does bear a little bit of the load but the rails does the bulk of it. On the left the single Z pillar which is a Hiwin 25. The two Z axis trapezium threads are not bearing any load other then the weight.
On the rear view you can see the plate that mounts it to the Z carriage with the tramming mechanism. The two screws on the right are for adjusting bedlevel parallelity in X and the block at the left is the locker.
The reason for building this is to see what I can get if I follow the principles of a milling machine instead of the light weight frames from the 3d printing world.
In the 3d printing world we have flex and vibrations from the frame and elasticity from those belts everywhere. We solve this by light weight and then software trickery.
In milling machines and cnc machine centers, we have the same problems but the forces are much higher. Here we solve it with stability, rigidity and weight low down. Never with a frame around the whole thing and never with software.
This frankenstein of a machine is not yet finished and it will be slow in the beginning. I have two nema 23 steppers available for those ballscrews (Y axis is also with a ballscrew), but with a pitch of 5 mm per rev it might not be fast enough.
One thing is for sure though, with 65 kg nearly at bed level it will be accurate.
If it works, and that is a big if, I might try rebuilding it later with servos for X and Y. I still don't know if the small nema 17 are strong enough to lift all the weight but I reserved some whopping 56 mm motors for it so we will see, there is a chance it will work.
since the X and the Y are split in bedslingers, you will not need to build rigidity for the Y direction in the X axis, because it does not translate to there. The beefy foot plate with those solid feet will easilly absorb any vibration from the bed so the X will hardly see any of that.
At leats that is the theory.
If this thing works I will use it for difficult materials that need hardened nozzles and I will put in in some enclosure with temp control.
This is future music however. As of now it is still only half built and although I have all the parts, my mind is as restless as a kitten on a caffeine shot, so I keep giving myself other projects to unfinnish.
