BigTreeTech SKR 1.4 wiring.
Saikedo
Voron 2.4r2 (350x350x350)
Hi, I was wondering if someone knows where can I find some guides or wiring diagrams for SKR 1.4 when building Voron 2.4 R2. Voron documentation has some good material but I was not sure how I am suppose to connect and use the second board since it seems like I need 2 SKR 1.4`s for Voron 2.4.
Thanks.
Saikedo
Ah I see, so they get connected as separate modules then and are not meant to be connected to one another right? (meaning one will not serve as an expansion for the other one). Thanks.
ah2049
That is correct. Both boards connect to the Pi, which is the brains behind the operation, which will then send and receive information to and from the appropriate board (MCU).
