Help with filament runout sensor not triggering
HoloPuff
Hey gang.
I have an LDO 2.4 kit with Octopus board and Klipper. I hooked up a filament runout sensors to Pin PG11
This is the config I'm using: https://github.com/VoronDesign/VoronUsers/blob/master/printer_mods/JD/RefillPlease/klipper/filament_runout_detection.cfg
(I just changed the pin). When the filament runs out, the sensor will change led from off to on, (it has a LED at the endstop) but the printer just goes on printing.
I've included the file in printer.cfg but no idea how to debug this now.
Is there a way to query the status of a pin? What am I missing here?
Thanks!
claudermilk
I installed the RefillPlease runout sensor and it works well for me. Here's the entirety of my config for it:
#     RefillPlease - Filament Runout Sensor
[filament_switch_sensor runout]
switch_pin: !PG14 # Pin Stop_6 for Octopus mcu
# Without M600 macro (uncomment the line below and comment the two lines in the "With Filament change M600 macro"
# pause_on_runout: true
# With M600 Filament change macro
pause_on_runout: false           # False activates ability to use runout_gcode instead of just running PAUSE automatically
runout_gcode:
    M600               # Code to run when runout is detected
insert_gcode:
    {% if printer.print_stats.state|lower != "paused" and printer.print_stats.state|lower != "printing" %}
      RESPOND MSG="RUNOUT: Filament inserted. Run LOAD_FILAMENT to prime nozzle."
    {% else %}
      RESPOND MSG="RUNOUT: Filament inserted. Filament load starting in 20 seconds."
      UPDATE_DELAYED_GCODE ID=_RELOAD_RUNOUT DURATION=20
      LED_PRINTING      # Code to run when new filament is inserted
    {% endif %}
[gcode_macro M600]
description: Helper: Called to pause when runout detected
gcode:
  {% if printer.print_stats.state|lower == "printing" %} #only do this if it's actually printing
    SAVE_GCODE_STATE NAME=STATE_M600
    RESPOND TYPE=error MSG="RUNOUT: Filament runout!"
    PAUSE
    LED_FILAMENT_RUNOUT
    RESTORE_GCODE_STATE NAME=STATE_M600
  {% endif %}
[delayed_gcode _RELOAD_RUNOUT]
gcode:
    LOAD_FILAMENT RUNOUT="true"
