Klipper LED effect
Here are the relevant definition blocks in my config.
[led_effect logo_homing]
leds:
    neopixel:sb_leds (1-8)
autostart: false
frame_rate: 24
endstops: x, y, z
layers:
    static 0 0 subtract (0.5,0.5,0.5)
    breathing 8 0 add (0,0.6,0.2),(0,0.46,0.15)
    chase 0.25 0.25 add (0,0.6,0.2)
    homing 4 0 top (0.75,0.75,1.0)
[led_effect logo_meshing]
leds:
autostart: false
frame_rate: 24
endstops: z, probe
layers:
    chase -0.30 0.40 add (0.2,1.0,0.0),(0.75,0.79,0.00)
    homing 2.5 0 top (0.75,0.75,1.0)
The magic is first defining the endstops, then that homing layer and putting it on top. With the above definition my SB logo LED flashes white when the endstop is triggered. It was tough to get that figured out (I had to get assistance from the developer).
Sorry to drag this thread up from the dead, im struggling to get my homing to work, i can get the breating and chase to work, but triggering the end stops (sensored z and sensorless X and Y on a voron 0.2) doesnt add any effect, not sure if i am missing something simple?
[neopixel bed_light]
pin: gpio24
chain_count: 14
color_order: GRBW
initial_RED: 0.0
initial_GREEN: 0.0
initial_BLUE: 0.0
initial_WHITE: 0.0
[led_effect sb_bed_homing]
autostart: false
frame_rate: 24
endstops: x, y, z
leds:
neopixel:bed_light
layers:
breathing 3 1 add (0.0, 0.6, 0.2, 0.0)
#chase 0.25 0.25 add (0, 0.6, 0.2, 0.0)
homing 1 0 top (0.0, 0.0, 0.0, 1.0)
Any ideas?
Hi @Mr.P1nky1989,
For an effect that reacts on the endstop you have to use the "homing" effect. This will light up when the endstops are pressed during homing or probing. Make sure the effect is active before you start homing (set autostart or use SET_LED_EFFECT)
To test maybe try putting only the homing effect and see if you can get that to work. Try (1,1,1,1) as color.
To combine it with another effect a useful method is to set the color of the homing effect to white and multiply it to another effect. This will activate the underlying effects when the homing effect is active.
Example:
[led_effect homing_chamber]
autostart: false
leds:
neopixel:chamber_light
layers:
homing 2.0 0 multiply (1,1,1)
gradient 0.5 2 top (1,0,0),(0,1,0),(0,0,1)
endstops: z,probe
Yeah, it looks like it might be broken. I've had the homing effect working on my Trident and V0.2 for a while now. Just homed the V0.2 and no LED indication, so the effect didn't work.
The definition posted above looks correct.
Apparently due to some internal Klipper changes the endstops now have to be called "stepper_x, stepper_y and stepper_z" instead of just "x, y and z". "probe" stays unchanged. So define your effect like this and it should work:
autostart: false
frame_rate: 24
endstops: stepper_x, stepper_y, stepper_z
leds:
    neopixel:bed_light
layers:
I will correct the documentation.
Sure enough, that fixed it on my V0.2. Trident is on a print job, so I'll update there later. Thanks for the tip.
autostart: false
frame_rate: 24
leds:
    neopixel:bed_light
layers:
this saved me after 8 hours of madness 🤡
julianschill / klipper-led_effect should also update his docs.
thanks to Hagbard
Just installed my Neopixel on an Stealthburner. I can call the effects up manually with the Gcode tabs on my dashboard but I dont know how to call them automatically when doing the actuall process like homing, heating, probing etc
The way I have it set up is a 3 step process: 1. define the LED effect. 2. Define a simple macro to turn on that effect. 3. Call that macro from within the function macro.
So for example, when running a bed level I have t he following for LED effects:
[led_effect nozzle_homing]
leds:
    neopixel:sb_leds (9,10)
autostart: false
frame_rate: 24
endstops: x, y, z
layers:
    #homing 4 0 top (1.0,1.0,1.0)
leds:
autostart: false
frame_rate: 24
endstops: x, y, z
layers:
[led_effect case_homing]
leds:
    neopixel:caselight
autostart: false
frame_rate: 24
layers:
    chase 0.5 5 add (0.08,1.0,0.38),(0,0.35,0.11)
[gcode_macro led_homing]
gcode:
    STOP_LED_EFFECTS ;cancel all others
    SET_LED_EFFECT EFFECT=logo_homing
    SET_LED_EFFECT EFFECT=nozzle_homing
    SET_LED_EFFECT EFFECT=case_homing
Then I have an override macro for G28 that calls the LED macro:
[gcode_macro G28]
description: G28 homing with SB LED status
rename_existing: G2828
gcode:
  LED_HOMING
  RESPOND MSG="Homing"
  G2828 { rawparams }
  UPDATE_DELAYED_GCODE ID=_CLEAR_DISPLAY DURATION=1
  LED_STANDBY
It takes a bit of study to figure out the settings. Definitely spend some time going through to docs: https://github.com/julianschill/klipper-led_effect/blob/master/docs/LED_Effect.md
Essentially you have the [led_effect <name>] block to define the actual effect to do--that's all covered in the above-linked docs. After that, I have a macro to call the effects; this is mainly because I have three groups of LEDs I'm driving at a time: the case light strips, the tool head nozzle lights, and the tool head logo panel. You could skip this and just call the SET_LED_EFFECT line directly in you other macros. In my setup, finally I call that middle macro where I want to activate the effects. So for example to set the LEDs to my settings for a print job In print_start I'd call my print lighting setup. In the clip I posted, I call that when doing homing, so you see in the last block I have overloaded the G28 command with one that just calls the base G28 after I call my LED_HOMING macro to turn on the LED effects for homing. Then it ends with calling my LED_STANDBY to set the effects back to the idle settings I have defined.
