tx_wombat
- FYSETC 0.2 Pro R1
- Other
New FYSETC 0.2 Pro R1 which uses the Catalyst board pre-loaded etc..
1. On boot I'm getting a error- No trigger on x after full movement and its pushing the X-Asix into the rear right side constantly - TRying to home but sensorless is not working (should be active by default).
Y and Z appears to be fine.
2. The bed heater / nozzle heater do not appear to be heating up and error out when I manually set the temps in klipper web interface. - the sensor type / heater type should bet set by default - the Github on FYSETC doesnt mention needing to make changes.
thanks for the help.
