- Voron 2.4 (250 mm)
- Clockwork 2
Hi All!
I've just finished building my Voron V2.4 based on Octopus Pro (STM32F446). According to the wiring doc, I connected my hot-end heater to the HE0 screwed connector (PA0 pin). When my assembly was complete, I started testing the heater. I set the target temperature to 50 degrees. Mainsail UI showed me that heating was started, but the temperature was not growing and after a few seconds Klipper reported a heater error and disconnected.
I double-checked my wiring. Everything seemed to be fine, but the heater did not work. Then, I tried to measure the voltage on the screwed connector HE0 after triggering the heater one more time, but the multimeter showed zero.
Then, I changed the Klipper config to use PB11 as a heater pin, reconnected wires to the HE3 connector and everything started working as expected.
Does anyone know what could be wrong with the HE0 connector? May it be due to misconfiguration or my mainboard has a defect? This is the first time I'm dealing with BTT Octopus, I already used BTT Manta before on my other machine and I have not faced anything similar. So, any help would be much appreciated.
		 Glad it's working now.
