Hi guys, I am considering building a Voron 2.4 25cm and I am currently checking the BOM to see if I could manage to do it or not.
I decided that in order for the build to be of a higher quality than some kit printers, one of the key points is to choose the quality steppers ( at least I think so . Since I'm a noob in this area, for me expensive == good quality lol.
The BOM for 2.4 lists NEMA17 Motor 17HS19-2004S and NEMA17 Motor 17HS08-1004S. When I try googling these, some no name steppers pop up. I'd prefer smth from a reputable manufacturer, such as Sanyo. I found one which looks promising as the replacement for the 2004S: https://www.farnell.com/datasheets/2920632.pdf by Sanyo, at least the dimensions, shaft length/shape seems to be identical to what the BOM recommends. However, the 1004S is tricky - the closest I've found is this one https://uk.farnell.com/sanyo-denki-sanmotion/ss2422-5041/42mm-slim-pancake-stepper-motor/dp/1708573, but the shaft is waaaay too short ( 7mm ??? ) Is this stepper motor somehow 3D-printing-industry-specific, so only very few makers such as LDO do them?
The reason I am asking these questions is because nobody seems to bother with steppers - most simply buy an LDO motor or a no name from Aliexpress.
Thanks!
Thanks!
