I'm running stealthburner with CW2 on my 2.4 and have tap installed using an OptoTap PCB OPB sensor and Hartk1213 5-24v stealthburner pcb. My Z endstop/probe for Tap are always triggered in klipper and I do not understand why. From reading the Tap manual I shouldn't need the 220 ohm resister or do I. When I lift the print head up I see the red light from the optical sensor and it turns off when I let go of the print head so I know it is getting power. I checked my connections and everything seems to be correct. What am I missing? I've tried This is my 1st Voron build. Thanks!
