Wire management?
msaeger
What are people using for wire management one the under deck wiring? Those channels that LDO includes look nice not sure how big they are though.
I found These that are 1.18" wide. Is that too wide?
Is there anything better to use? Those things you mount a zip tie with are nice but I am expecting to be moving wires around so something less permanent is better.
That is the narrowest I could find on Amazon. There seems to be 25mm x 25mm wire trunk available outside the US. Keep us posted on what you find.
Here's a printable one. Not sure how what would turn out.
This looks like it might be a good one. There are positive reviews as well in the comments. I made copies of the STL's. If you run across any others, please share. Thanks for posting it. (y)
The only thing I don't like is there is a bridge between the pins so you would need to feed the wires through the hole or cut off the bridge I guess.
