- Voron 2.4 350mm
- Clockwork 2
I can't seem to figure out where I've gone wrong. My z axis won't go up, but only while printing. It homes as expected, I can manually (via web/front panel) move it up and down, and there seems to be no rubbing anywhere. It's like it's stuck on the same layer but only when printing.
It's recently been assembled, then moved, and I have had a few successful prints with it. I decided I wanted to set my Z-Offset in my firmware instead of my slicer software to make changing slicers easier when needed, and that's when things went sideways. I've compared (what I believe was) a working CFG to the current one, changed everything that was relevant (ie not the nozzle diameter) and I'm still having issues. I'd love any pointers or suggestions.
I've been printing for nearly a decade, but this is my first printer running klipper and I'm not afraid to admit I feel really out of my element, especially since evidently I'm too dim to fix this seemingly simple problem.
Pastebin of my printer.cfg
pastebin.com
Thanks all!
![pastebin.com](/proxy.php?image=https%3A%2F%2Fpastebin.com%2Fi%2Ffacebook.png&hash=dfe7986e49526130bd9483ee59cda2df&return_error=1)
# This file contains common pin mappings for the BigTreeTech Octopus V1.# To u - Pastebin.com
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
Thanks all!
