I agree, I don't know how a stepper motor may "lag" the others (thus why I am checking with this group!) Anyway, taking measurements it looks like the others move 25mm but Z1 only moves 17mm and skews the gantry. If and move another 25mm in the same direction then it moves 25mm, but maintains the relative skew. If I reverse the direction, then it again "lags" and only move part of the distance (again, about 17mm). From this i started to think that the other steppers are dragging it along and the mechanical flex in the gantry is causing the delayed movement.
Following up on that, I ran the gantry up and down 300mm several times and confirmed the behavior, but more importantly checked the temperature of the four Z steppers. Z0, Z2, and Z3 were a little warm at the end, by Z1 was cold. I suspect Z1 is dead and needs replacement. I will first check all the connections and make sure nothing has changed (it was working just fine for several months before, but seems to have stopped working when I went form Octoprint to MainsailOS and upgraded Klipper to the latest earlier this week). If that all checks out, then I will pull the stepper.
I will post what I find.
