Now that's an exemplar build documentation, I want to be like you when I grow up.
			Thanks for the kind words, @vinnycordeiro @hartk @Daniel@West3D @Rhastlyn!As the others have said, wow, this is a great build log! Did you take the pictures with this in mind?
Seeing this build really makes me want to build a micron. The 180 is neat but there's just something about the 120 that I really like.
The stadium lighting is a very clever idea, would be kinda neat to see something similar on a v2.
CAN really cleans it up, although given the amount of wires you had to run previously it was still very tidy.
Love the build!!! without a doubt my favorite Micron!
		Yeah, this was one of the unfortunate compromises with going to EBB36. I even swapped my Z chain down to the slimmer style that doesn't open, and reduced the length of the motor mount standoffs to 16mm. Currently, I have 102mm of Y travel, but if I really cinch down the connectors and wires on the rear of EBB36 and shift the bed forward, I think I can get it back to around 110mm.Nice build, looks great!
I have my Micron close to finished, but have problems with clearance of EBB36 on Z-Chain, Umbilical Mount on gantry. Iam running a LGX Lite. Does everything fit with the Dragonburner and HextradORT without loosing Y and modding the Klicky mount?
EDIT:
I missed the part where you described lost y. How much Y do you have avaibale with your current setup?
It's been interesting and mostly positive. I hadn't played with any of the other skeletonized extruders before (Sherpas, Sailfins, etc.), and ended up choosing the VZ-Hextrudort because of the quirkiness of the offset motor and the helical gears for filament feeding. Was running into weird feeding issues until I upped the run current on the extruder stepper driver. Since then, it's been running really well. Exposed large gear makes feeding and removing filaments with the thumb both easier and harder. Easier because there's no need to open a latch or clip the filament tip a certain way to get it to insert into the reverse bowden smoothly. Just feed it through and turn the gear to advance the filament. Harder because removing filament by turning the large gear is not as easy as just yanking filament out like with miniAB/miniSB.How do you like the VZ extruder? I haven't seen much feedback from users.
I'm sad to see the Mini SB go, I love the look of it.
Great work as always!
bawrharwharw, acceptable problem to have - time for the next printerI think I've run out of mods.![]()
