FYSETC 2.4 R2 Pro + CNC upgrade
PaulUK
"Build your own 3D printer!" Yeah I can do that. Hmmm time for a reality check:
Physically build the thing? Confidence is high.
Wire up the electronics without a) blowing something or b) electrocuting myself? Confidence is reasonably high.
Flashing firmware/software/can-bus/config files/macros? Confidence leaking away.
Am I too old to learn this stuff? Time will tell.
I started building Vorons at age 45 so you can do this too. If you get stuck, there are lots of us here to assist.
Coming along nicely, taking my time to enjoy the build, and putting off the day I have to deal with the electronics…
First off thanks to “claytono” for designing these brilliant little jigs to clamp the extrusions firmly in place when assembling the frame, I printed 4 off @ 98% making them a snap on fit, result was an almost perfectly aligned frame:
https://mods.vorondesign.com/details/SSoHrEC3VElDLwDLw2GA5Q
I modded the Z idlers to use countersunk screw with nyloc nuts so can be adjusted easily from the outside, and won’t vibrate loose.
The plastic bottom sheet below bed not supported along the sides so knocked up some simple wedge supports that clip tightly into the extrusions.
Also made some simple jigs that allow me to locate the bed accurately.
Overall I’m very impressed with this FYSTEC kit so far, it certainly isn’t a Cheap Chinese Clone.
Stealthburner; here I need help as FYSETC don't appear to do a manual specific to their version, and as there are numerous revisions/options I'm confused as to what parts I do/don't need to print off, anyone advise please?
I am pretty sure there is no version specific to FYSEC. Just print the latest one from the Voron repo.
Dude I am in my 50’s! You got this. I completed my v2.4 350mm back in August 2024. Never worked with anything powered by AC 120v.
Not sure of your skill level with electronics but don’t skip any testing of your wires. If you don’t have one, get a multimeter, around $30 bucks should do.
This forum is great for researching issues but also open a Discord account.
Finally don’t be afraid of rolling back your build to redo sections. In the end, it will haunt you if that may be the cause of an issue.
Thanx for the motivational speech! My main hobby is RC Helicopters, so building a printer is pretty much the same, belts & pulleys, electric motors, setting up electronics, accurate alignment etc. I do have a multi meter and know my way around basic electronics, what I wasn't aware of, and where I have little experience, is with the software side; creating/editing config files, firmware, macros, all of which is unfamiliar territory for me.
I find Discord & GitHub complicated to navigate, the info is in there, just often hidden away amongst a mountain of irrelevant (to me) details. Had I known of these complications a few weeks ago, I probably would have thought twice about ordering a kit, having now committed a large sum of money in this project it will get completed :)
Assembling the Stealthburner I'm slightly confused by a cryptic note on Spider wiring diagram "Need AD597 add on", plus came across a build thread where the author intends to use an external thermistor with special mount on the hinged cable cover for one? https://www.jonashietala.se/blog/2023/10/18/lets_build_a_voron_toolhead/
Unsure which port on the Spider you are referencing. The system will have multiple thermistors. The one from the hotend reports it's temp and if it doesn't see an increase after a certain amount of time, klipper will crash itself to make sure it's not overheating due to a bad thermistor. This is called "Thermal Runaway".
The one that sits on the cover is the chamber thermistor. I don't use it in any of my macros but it will report the chamber's temp. You should have one on the bed as well. Same rules as the hotend.
The Chamber and Hotend thermistors should be plugged into the toolhead PCB. The bed and any other will go to the Spider (MCU).
It's not on the actual Spider the note is on the above pic of Sailfish at the bottom referring to needing a "AD597 add on"?
Just completed putting the Stealthburner together, tough job trying to (gently) squeeze the wires in, plus discovered that the plugs for filament feed motor and the RBG LED's were both wired incorrectly, need to check other wiring carefully.
Have reached a bit of an impasse; this kit is sold as umbilical version with parts to suit, however the CAN plug on SB passes over the umbilical mount making it impossible to use an umbilical. I've emailed FYSETC but have yet to receive a reply.
FYSETC never bothered replying to my email, after much searching online couldn't find a solution to the umbilical mount, so designed my own using TinkerCAD, not very elegant but functional.
Finishing the electrics found all 6 of motor wiring looms had pin 2 & 3 reversed on motor plug, that's 8 plugs in total that were wired incorrectly.
After checking wiring for umpteenth time powered it up at arms length..... anti climax, no smoke, bangs or blown fuses. (y)
Now the fun begins....... :unsure:
Hi Paul. Just wanted to say your build thread for the Fysetc Spider V3.0 H7 Voron 2.4 has been a nice resource, really appreciate you sharing your progress.
I'm currently working on my own build with the same kit, and I've run into an issue getting homing to work. I'm suspecting a wiring mistake on my stepper motors, specifically the color order of the z steppers.
I'm seeing this error when attempting to home:
TMC 'stepper_z' reports error: DRV_STATUS: 001f00e0 s2vsb=1(ShortToSupply_B!) ola=1(OpenLoad_A!) olb=1(OpenLoad_B!) cs_actual=31<br>
If it's not too much trouble, would you mind posting a quick photo of your stepper motor connectors showing the wire color order? It would be immensely helpful.
It's been a while since I looked at mine, although powered up I have yet to write the config file etc. other commitments have taken precedence for now, so you're ahead of me. I did have problems with the supplied wiring looms being incorrect and had to correct a couple of them, the motors I can't remember but the actual wire colours aren't important (mine are different to drawing) just that they connect to the correct pins on MCU & motor.
Finally found the issue, and yes that error I posted came after I had all the cables with the exact same connections as in that pdf. The machine was able to power up without exploding but the moment I tried to home it, klipper complained with that error in all Z and A, B motors. It starts complaining about stepper_z but if you disconnect that one, it complains about stepper_z1 and so on.
I tried a lot to re-interpret the confusing motor schematics pdf and tried many combinations of connections but what ultimately solved the issue was testing the motors with a multimeter. Turns out that the coils are wired completely different from what I expected from the pdf. Of the pins 1, 3, 4 and 6 they use, the 1 goes with the 4 and the 3 with the 6, at least with the motors I received.
On the spider side, the pinout image they have on github is clear about what are the A coil pins and what are B.
After figuring that out I decided to name 1, 4 => A and 3, 6 => B (or B and A, I don't remember) and the error disappeared. Now the issue was that all motors were going in the opposite direction, but I didn't have to re-wire them again, I switched the dir_pin adding a ! exclamation mark in all of the steppers, or removed it if it already had one, and finally was able to home it.
Yesterday I did the first print. It failed mid way because of an issue with the extruder which apparently lost grip of the filament, but that's a different story.
