Gantry struggles to reach xy endswitch
orge
On my 2.4 the I am struggling to get the extruder to touch the xy limitswitch. It is running fine in the middel, but somehow it cannot get all the way back.
Any solutions ?
Can you post a photo of your gantry and your XY endstop? Where do you have it located? Do you use pod on the left XY joint with both switches, or on the A motor mount?
Did you de-rack the gantry?
I just found, that my gantry was smaller near the motor, hence the difficulty. - problem solved
Was a bit to fast to state solved. Now y is working, but x is grinding, and not moving. Have tried disconnect one motor at a time, and both seems to run correct.
Now it is solved hadvto invert x-acis
Are you going through this guide? It's a really good document describing initial steps to get your printer going, including what to do in case movement goes different direction during homing.
