Self sourced 2.4 R2. My first 3D printer ever
Found a post on discord that said,
"but as to your actual problem, I think telsler is right. anywhere you have spaces BEFORE a [ ] section, I think that is trouble
so go through, and all section headers, aka stuff like [gcode_macro PAUSE]. make sure the [ is the first character on that line
I had a space in front of the [gcode_macro BED_MESH_CALIBRATE] I just pasted in to fix the previous error message.
Got rid of that space and I'm back to the same error message: Existing command 'BED_MESH_CALIBRATE' not found in gcode_macro rename
Pumped that into discord search and found out I didn't have a [BedMesh] in my printer.cfg.
Found one here: https://docs.vorondesign.com/tuning/secondary_printer_tuning.html
I do have some/3 bell warnings about moonraker. But maybe those can wait.
Onward toward my next puzzle.
After all the wiring is done and you hit the ON switch,
Are the fans on the stealthburner supposed to start running?
I used pin PA1, the bolt on the end that is normally used for the bed heater, for the hot end heater.
I guess all the kids are doing it.
Since the bed heater is controlled by an SCR that doesn't draw much, it's connected to HE0.
The hot end should draw more and PA1 is built to handle more amps.
The reason it didn't work, is because I had the hot end connected to the 24 volt bolt.
Apparently the hot end is supplied power at all times and is controlled by the negative wires.
Even though it's controlled by the negative post I still have it designated as PA1 in printed.cfg, not BED-P.
And it's working great now.
Next, things are going to start moving. Maybe in the right direction, if I wired the steppers properly.
Running through the BUZZ command.
If the stepper motor oscillates in an incorrect direction, then it generally indicates that the “dir_pin” for the axis needs to be inverted. This is done by adding a ‘!’ to the “dir_pin” in the printer config file.
That means put the ! in front of the pin like this: dir_pin: !PF12 not in front of the whole line.
So I must have wired them wrong, glad there is an easy fix instead of having to depin and swap wires.
I am wonder what this means:
The STEPPER_BUZZ command will cause the given stepper to move one millimeter in a positive direction and then it will return to its starting position.
What is a "positive direction"? I took it to mean away from the outer edge of the machine.
So I had to invert Y but not X.
Seemed like it was moving more than 1mm so I changed rotation distance from 40 to 30 in X and Y
Well in a world where up is down and right is forward,.. it would be moving great, ha.
I bought it back into the world where up is up and right is not forward.
Next my probe is always triggered so I can't move the gantry down.
Doesn't change if I push the klicky probe switch or not. Even though the blue klicky light goes out when I push the switch upward.
Probably another wiring problem.
Found this thread on here and with octopus V1.1 hartK 2-piece board the klicky is supposed to be plugged into J34 with ^PG15 pin in printer.cfg. instead of the J40/PB7 plug.
The ^ enables the pullup resistor.
The probe trigger works now.
Setting up auto z calibration and got this error:
Option 'probe_nozzle_x' is not valid in section 'z_calibration'
I guess they updated the syntax or whatever it's called.
This topic helped me understand:
the new standard that uses nozzle_xy_position instead of the old probe_nozzle_x and probe_nozzle_y.
Deleted the old cfg file with the "probe_nozzle_x" style and pasted the z-calibration cfg from here:
Included it in the printer.cfg with the proper _ or - that matched the name of my klicky-z-calibration and no errors,.. for now.
I am still here.
Took along break from building the printer.
Now coming back to it and doing some updates and figuring out new problems.
I get an error:
Unable to parse option 'fan_speed' in section 'heater_fan hotend_fan'
I keep finding that a simple indent or uncomment has cured it for others but I don't see anything wrong in the area following it:
## Hotend Fan - FAN1
[heater_fan hotend_fan]
pin:PE5
max_power: 1.0
kick_start_time: 0.5
heater: extruder
heater_temp: 50.0
## If you are experiencing back flow, you can reduce fan_speed
fan_speed: 0.5
## Controller fan - FAN2
# [controller_fan controller_fan]
# pin: PD12
# kick_start_time: 0.5
# heater: heater_bed
# fan_speed: 0.5
## Exhaust fan - FAN3
# [heater_fan exhaust_fan]
# pin: PD13
# max_power: 1.0
# shutdown_speed: 0.0
# kick_start_time: 5.0
# heater_temp: 60
# fan_speed: 1.0
I see there is a silly face on a section of the code where I didn't put a space after a colon.
I put the space but still have the same error message.
So I started looking for examples and found this one:
## Hotend Fan - CNC_FAN1
pin: PE5
max_power: 1.0
heater: extruder
heater_temp: 50.0
#fan_speed: 1.0
And mine:
pin: PE5
power_max: 1.0
heater: extruder
heater_temp: 50.0
fan_speed: 1
I changed mine to match the example
changed to max_power instead of power_max and commented out the fan_speed
Is auto z not supported anymore?
klicky-z-calibration is no longer in the klipper macros list.
I also tried uploading it to klipper/klippy/extras using winscp but it never showed up in the config files list.
Tried SSHing it in too
I'm still plogging away at this.
Sometimes wondering if I'm in over my head, then I reach the surface and get a gasp of air.
I actually had it doing a QGL, auto z was working great checked the bed for flaness.
Took a break while I figured out how to enclose it and mount the spool.
Found clicky-clack door idea and glad I didn't use the 2 swinging front doors.
I don't have a printer to print up parts link hinges for the clicky_ clack door so I used bifold door hinges.
Metal and they work great.
Got back to it and did an upgrade,... then autoz didn't work anymore.
Started from scratch and relearned everything. Got it back to QGL, almost.
I was having bad connections with WIFI and it kept disconnection.
So I tried to connect it through the ethernet cable using this:
Video by the same folks:
Now I can't even get into the Pi. raspberrypi.local worked before. But not now.
Can't SSH into it using putty anymore. It just times out. Same problem many people had in the comments on the video.
Maybe should have read the comments first.
Tried to find it using angry IP scan and couldn't find the Pi.
What are my options?
Maybe hook a screen up to the Pi to find the IP address?
Or do I need to start all over again with the software/firmware?
OK I was able to use putty, not sure what changed.
Maybe just shutting things off and coming back to it later?
IF config looks like this:
pi@raspberrypi:~ $ ipconfig
-bash: ipconfig: command not found
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether b8:27:eb:35:62:17 txqueuelen 1000 (Ethernet)
RX packets 49 bytes 5204 (5.0 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 141 bytes 25681 (25.0 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 11 bytes 1661 (1.6 KiB)
TX packets 11 bytes 1661 (1.6 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.88.15 netmask 255.255.255.0 broadcast 192.168.88.255
inet6 fe80::9ba8:5b3:57b7:7039 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:60:37:42 txqueuelen 1000 (Ethernet)
RX packets 1495 bytes 199613 (194.9 KiB)
TX packets 848 bytes 867995 (847.6 KiB)
pi@raspberrypi:~ $ git clone https://github.com/protoloft/klipper_z_calibration.git
Not sure what the git clone thing is. I didn't type that.
What does that inet line mean in the wlan0 group?
I typed the 192.168.88.15 into my address bar and initializing, initializing etc. It finally came on,.. then "connection failed" TRY AGAIN.
Back to where I was before this last ordeal. Got a breath, ha.
Still would like to learn how to connect it through ethernet so I don't have to deal with the bad wifi connection.
Big plan is to get back in and copy/backup all the cfg files.
Then look around for a tutorial on how to connect directly to the Pi through cable.
I've been called unhinged well here's proof I'm not,.. always.
Bifold door hinges that were cut down.
The pin is removeable so the door can come off.
voronhinge by vwfatmobile, on Flickr
I used greenhouse polycarbonate for the sides and top because I had some.
To answer your question about "What does that inet line mean in the wlan0 group?"
It means IP (internet protocol v4) the next line has your IPV6 hex.
It also shows you have no ethernet cable plugged in, I assume you are back on wifi?
Sorry to keep chiming in, I guess I could edit my other posts, but you might miss it!!!
Plugin an ethernet cable while you have it on wifi and see if it grabs an address by running ifconfig again...I notice you figured out this isn't Windows on the printers...
Thanks for the response.
It's working again.
The Pi address has changed since I tried getting it to work with the ethernet cable.
But I am able to go to put the new IP in my address bar and get it all working.
Still not connected through eithernet cable so can get kicked off from time to time.
I did the PID. It went well, OK had to swap PA1 and PA2 in printer.cfg. Then it went well.
I can home X Y and Z.
When trying to do the QGL klicky wouldn't touch the bed. # Now that I changed stepper_z_min in printer.cfg. From -.5 to -2 it would QGL.
I carved a klicky dock from a piece of wood, (I mentioned I don't have a 3D printer right? ha)
After getting it to pick up the klicky from the dock it wouldn't touch the bed again. Stopped right above the bed. I changed stepper_z_min to -10.
And now it will pick up the klicky probe, do a QGL but...
When it goes back and tries to park the klicky, it comes in a couple mm too high and sets it in at an angle.
In my Klicky variables:
variable_docklocation_x: 81 # X Dock position
variable_docklocation_y: 333 # Y Dock position
variable_docklocation_z: 15 # Z dock position (-128 for a gantry/frame mount)
# location to park the toolhead
variable_park_toolhead: False # Enable toolhead parking
variable_parkposition_x: 81
variable_parkposition_y: 333
variable_parkposition_z: 13 # I moved this down 2 thinking it would dock lower but it didn't.
I forgot how to post code on here.
I carved the dock out of wood and mounted it to the bed rails.
So it might sit lower than the stock setup.
Is 15 too low? Is there some kind of safety over ride?
I also tried calibrate z and it worked.
I feel like I'm getting close to tuning it.
Have to figure out start code and super slicer stuff.
I did copy my printer.cfg and klicky variables files. So if something goes wrong I won't have to start from scratch again.
I'll have to take a look at my first post on here and see how long I've been at this.
I think it's been a couple years.
2026 is the year I push out some plastic, start tuning it and make some things.
Mostly parts for this voron.
I don't expect it to be a project that ever gets done, there will always be something I can improve. Learn how to design things etc. Bit of a terrapin station situation.
Thanks for all your support.
Looks like I started rounding up parts around April 30 2023,.. it's getting close to 3 years.
I've taken on and accomplished many difficult tasks since then, this challenge is in another class.
Which will make printing things even more rewarding.
@5twenty I connected the ethernet cable and got this on the wlan section:
RX packets 28934 bytes 1667220 (1.5 MiB)
RX errors 0 dropped 103 overruns 0 frame 0
TX packets 32612 bytes 16918065 (16.1 MiB)
Doesn't look much different than the last time.
Not sure what it means and how can you tell if the cable is connected?
Do I have a bad ethernet cable?
I can get through an xyz home,
a QGL,.. it picks up the probe, checks the 4 corners and adjusts the gantry, then puts the probe back a little high, but I can deal with that until I print up a proper dock.
Then I get to the CALIBRATE_Z.
It won't pick up the probe.
I get a Unknown command:"M401" complaint.
If I put the probe in it's hand it will go through the steps, z switch on the nozzle, z switch on the body, goes to the center probes a few times then stops
I get a Unknown command: "M402" complaint while it stands there just looking at me.
Kapman's basement suggested I define M401 and M402 in printer.cfg but I'm not sure how to do that or where to put it.
In klicky-quad-gantry-level.cfg, it has an Attach_Probe command in the middle and it has Dock_Probe at the end and it puts the lotion in the basket when told to.
It doesn't use the M401 or M402 so it picks it up and drops the probe off "correctly".
# Quad Gantry Level
[gcode_macro QUAD_GANTRY_LEVEL]
rename_existing: _QUAD_GANTRY_LEVEL
description: Conform a moving, twistable gantry to the shape of a stationary bed with klicky automount
gcode:
{% set V = printer["gcode_macro _User_Variables"].verbose %}
{% if V %}
{ action_respond_info("QG Level") }
{% endif %}
_CheckProbe action=query
G90
Attach_Probe
_KLICKY_STATUS_LEVELING
_QUAD_GANTRY_LEVEL {% for p in params
%}{'%s=%s ' % (p, params[p])}{%
endfor %}
Dock_Probe
Curious, is the fan supposed to be hissing at me during all of this?
I think the reason the klicky probe doesn't park it in the dock I made is because it's mounted on the bed frame instead of the gantry.
It picks it up fine after xyz but after the QGL that corner of the gantry isn't at the same distance from the bed.
I've been going through ellis tune stuff and took the suggestion to loosen and retighten the verticle z-bolts after a QGL.
It seemed to help. It drops the probe off better now.
Still have the problem of a Unknown command:"M401", kind of.
Time for me to learn some g-code. I wrote/pasted a M401 g-code command.
#macro do deploy klicky probe
[gcode_macro M401]
gcode:
G90
{action_respond_info("Entering M40)"} ; oops should be M401, since it's just an error message it shouldn't cause an error right? I'll change it.
error_if_probe_deployed ; check to make sure that the probe is not already attached
_M401
[gcode_macro error_if_probe_deployed]
gcode:
QUERY_PROBE ; check probe status
do_error_if_probe_deployed ; logic check to verify probe is not already deployed
[gcode_macro do_error_if_probe_deployed]
gcode:
{% if not printer.probe.last_query %}
{action_raise_error("klicky Probe is already deployed - Remove and Return it to the dock")}
{% endif %}
#Macro to Deploy Bed Probe
[gcode_macro_M401]
gcode:
G90 ; use absolute coordinates
{% if printer.probe.last_query %}
G0 Z20 F3000 ; raise up to safe height
G0 X81 Y300 ; stop in front of dock
G0 X81 Y333 ; stop above dock
G0 Z15 F3000 ; lower onto the klicky to attach
M400
G0 Y300 ; pull it from the dock
G4 P250
{% endif %}
error_if_probe_not_deployed
{action_respond_info("Exiting M401")}
I put it at the end of printer.cfg in the MACROs department.
Now I get this error when I try to run auto-z:
Section 'gcode_macro_m401' is not a valid config section.
Lot of searching, not sure why I'm the only one with these M401/M402 problems associated with auto-z.
