Having built my Tap I thought I should test it before continuing with the build.
I havent yet installed the rest of the electronics so this has nothing to do with config files etc. I was just testing the Tap hardware & PCB
I applied 5v to the red and black connections and the LED lit up Red. Moving the tap manually did not change this. This seems to be at odds with what I was expecting. My understanding from looking at the circuit is that the LED should be blue when not triggered and turn red when triggered.
I took the PCB out and tested it again using a piece of card to obstruct the optical path. Once again, the light stayed permanently red.
Does this mean there is something wrong with the PCB? Or have I misunderstood?
Peter
Peter
