Question Trident build using BTT SKR V1.4 and CANbus toolhead?
wanders
Voron Trident
Feasibility question: would it be reasonable to build a Trident using a BTT SKR V1.4 (non-turbo), remapping the klipper/config/generic-bigtreetech-skr-v1.4.cfg to drive the A, B and 3 Z steppers, and use a CANbus toolhead board with a USB-to-CANbus adapter on the RPi? I'm trying to reuse some parts from my stash, namely:
a) Raspberry Pi 3B host
b) BTT SKR V1.4 (LPC 1768) primary MCU
c) 5X TMC2130 stepper drivers
d) Meanwell SE-450-24 (24V, 18.8A) 450W power supply
Other than less than leading-edge performance, what would be the downside in this configuration?
Best regards,
Willie
the ebb36 boards I believe can run over usb also .I wanted to try / do something similar
Probably worth clarifying, there are specific ebbs designed to run over usb. Running the regular canbus ones over usb ...well...it's possible, but probably not a great idea
