Tronxy x5sa -> Franken Voron Build
I do .. its a bit messy though :)
basically I hate bed leveling ..
If you wanted to go with a x5sa style Z, I can try to dig up my old Voron 1 style files, it re-uses the linear rods, and sets thing up to basically match up Voron 1.8 style Z axis ..
That worked "ok" but not great (I mean there is a reason the Voron Community went from the V1.8 design over to Trident :)
With Trident you get 3 independent motors driving the bed, allowing for Klipper to fully adjust the bed tilt automatically for you, with the V1.8 style bed, Klipper can adjust the left to right tilt (to a degree, without the fancy bearings Trident uses, the bed is a big stiff left to right, so you never want your tilt to get too far out, since you're basically putting a lot of shearing force on your bed mount.
My advice would be to skip the V1.8 phase .. but you're welcome to go down this path and try it out :)
Give me a few days to see if I can export out the right STLs .. and maybe export out some working version of the CAD :)
@piotrb I understand the sentiment on bed leveling. I have a Voron 0.2 and I wish it had automated bed meshing and a sensor as standard with the design.
I have been working on a CAD using Fusion 360, but I stalled on it because I'm new to CAD. (I'm taking the Trident gantry, the Tronxy Z motion, and shifting the rods inside the frame.)
I had that all basically figured out .. I'm exporting an older version of my CAD for you .. (I wonder how massive the f3z file will end up being lol) .. it was fairly elegant if I can say so myself .. for that particular motion system anyways ..
