For an Octopus v1.1, the RGB pin should be PB0? I believe PG0 is actually the STEP pin for DRIVER1.Finished Initial Startup test through QGL. Looking good so far. I'm liking Tap.
The only issue I'm having is that the Stealthburner LEDs are not working. I'm using a Octopus V1.1 control board. The LED data line is attached to PG0. I even tried adding a 100 Ohm to the data line. I have not tried the alternate data line location of PG6 because the x-endstop is attached to it. I guess I'll move the x-endstop over and try PG6 for the data line. If that doesn't work I guess I'll take the toolhead apart to check the LED continuity to make sure nothing was damaged during installation...
Sorry I missed typed...I meant PB0...sometimes I type faster than I think...For an Octopus v1.1, the RGB pin should be PB0? I believe PG0 is actually the STEP pin for DRIVER1.
Did you pull off all the jumpers before you started wiring the control board? That seems to be a common mishap with users of the Octopus board at least... Hope you get to the bottom of it!well crap...I'm having extruder issues...received an error when I tried to extrude filament...may be a wiring or steeper issue not sure...the reported error is "TMC 'extruder' reports error: DRV_STATUS: 000f00e0..."
yep...thanksDid you pull off all the jumpers before you started wiring the control board? That seems to be a common mishap with users of the Octopus board at least... Hope you get to the bottom of it!
LOL 'bout the camera...I do need a close up lens.Congratulations.
Now you just need to put
a camera that takes better closeups on the list, to get the fine details.
It never ends.
Do you have a nevermore air filter? I see they have a couple folks on etsy making them.
