LDO Voron 2.4 Build with All Metal Parts
Up and running since late January with over 100 prints to date.
I print with PLA and PETG mainly, no requirements for ASA/ABS or fancier filaments at the moment.
I had quite a few failed prints in the beginning, mostly down to bed adhesion. I assumed it might be down poor assembly / alignment, it wasn't, it was the filament... after changing it, the issue went away...
Whats she look like again?
The manual did indicate the other way round, but when secured, it resulted in a lot more tension than I was happy with.
After reversing them I noticed they sit better, if necessary I could always add a few more turns to achieve similar tension, so I left them reversed...
Interesting. I actually went the opposite direction. After a QGL, I tightened them as tight as possible to remove the slack. Even IS improved.
A word of caution.
On two separate occasions a grub screw on one motor became loose, resulting in the gantry becoming considerably skewed, luckily I was able to switch off before any major damage was done.
Had I tightened these fully, I have no doubt I would have broken or bent the carriage, after all, these are designed to allow some flexibility to prevent damage under this exact condition.
I am no longer confident using grub screws with pre-applied locktite...
