wmattias
Hi!
Printing some pretty standard stuff, using PLA with fairly standard/conservative settings.
Most things print well, but I seem to keep having problems with corners that have overhangs. For some reason they get mangled if the corner degree is too high:
1. Any corner angle with no overhang works well
2. Straight overhangs work well
3. Corner angle of 45 degree and overhang of 45 degree works well.
4. However, Corner angle of 90 degree with overhang of 45 degrees gets mangled.
Posting some pictures below. It's probably some beginners mistake I'm making, just can't figure out what it could be.
Update: Added a 4th picture to give a better view of what is happening. Essentially, the outside of the 90 degree corners don’t stick to their layer height and instead curl upwards as the cool.
