Self sourced 2.4 R2. My first 3D printer ever
[gcode_macro _M401] ;needed a space here.
Got my M401 example from here: https://euclidprobe.github.io/06_klipper3.html
So here's what my M401 g-code probe attach looks like now:
#macro deploy klicky probe
[gcode_macro M401]
gcode:
G90
{action_respond_info("Entering M401")}
error_if_probe_deployed ; check to make sure that the probe is not already attached
_M401
[gcode_macro error_if_probe_deployed]
gcode:
QUERY_PROBE ; check probe status
do_error_if_probe_deployed ; logic check to verify probe is not already deployed
[gcode_macro do_error_if_probe_deployed]
gcode:
{% if not printer.probe.last_query %}
{action_raise_error("klicky Probe is already deployed - Remove and Return it to the dock")}
{% endif %}
#Macro to Deploy Bed Probe
[gcode_macro _M401] ;needed a space here before the _M401
gcode:
G90 ; use absolute coordinates
{% if printer.probe.last_query %}
G0 Z20 F3000 ; raise up to safe height
G0 X81 Y300 ; stop in front of dock
G0 X81 Y333 ; stop above dock
G0 Z15 F3000 ; lower onto the klicky to attach
G0 Y300 ; pull it from the dock
G0 Z20 F500 ; move up to elevation of Z20
{% endif %}
error_if_probe_not_deployed
{action_respond_info("Exiting M401")}
[gcode_macro error_if_probe_not_deployed]
gcode:
QUERY_PROBE
do_error_if_probe_not_deployed
[gcode_macro do_error_if_probe_not_deployed]
gcode:
{action_raise_error("klicky Probe failed to deploy!")}
{% endif %}
And it seems to work. Comes in a little low, moving to the center of the bed after probing the z-pin.
A little higher would make it more comfortable.
So stuck that and the M402 in the macro department of the printer.cfg and they are working fine.
# Macro to retract Bed Probe
[gcode_macro M402]
gcode:
G90
{action_respond_info("Entering M402")}
_M402
# Macro to Stow Bed Leveling Probe
[gcode_macro _M402]
gcode:
G90
{% if not printer.probe.last_query %} ; the logic on this needs function check
G0 Z20 F2400 ; set approach elevation of Z15 for fixed gantry system to clear probe over bed
G0 X175 Y175 F3000 ; start movements at center of the bed
G0 X81 Y300 Z15 ; move to position in front of dock
G0 X81 Y333 F240 ; put it in the basket
G0 X40 F240 F3000 ; quick swipe right off onto the dock
M400 ; wait for moves to finish
G4 P250 ; forced pause here so motion is definite 90 travel to swipe
G0 X175 Y0 ; move to front center of bed
{% endif %} ; exit the if-then loop. was missing in previous versions
error_if_probe_deployed ; verify that the probe is detached. is corrected error
{action_respond_info("Exiting M402")}
It doesn't drop the probe off real well but I can easily fix that.
Main problem is still getting kicked off by wifi.
having a hard time figuring out how to access the pi with the ethernet cable.
thernet adapter Ethernet:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 169.254.97.99
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Local Area Connection* 8:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Local Area Connection* 10:
Ethernet adapter Bluetooth Network Connection:
Wireless LAN adapter Wi-Fi:
IPv4 Address. . . . . . . . . . . : 192.168.88.19
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.88.1
And the ifconfig on the pi:
pi@raspberrypi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether b8:27:eb:35:62:17 txqueuelen 1000 (Ethernet)
RX packets 97 bytes 18285 (17.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 292 bytes 53576 (52.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1657 bytes 900345 (879.2 KiB)
TX packets 1657 bytes 900345 (879.2 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.88.15 netmask 255.255.255.0 broadcast 192.168.88.255
inet6 fe80::9ba8:5b3:57b7:7039 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:60:37:42 txqueuelen 1000 (Ethernet)
RX packets 4444 bytes 698095 (681.7 KiB)
TX packets 3012 bytes 1369155 (1.3 MiB)
This is with the cable attached.
Not sure what it all means. Not learning fast enough, ha.
I read this:
And watched this:
Seems to connect better. I still have to hit try again occasionally but it's connecting better.
Still not sure it's using the ethernet cable but last time I played with it, it was connecting better.
Of course this line wasn't swiping right:
G0 X40 F240 F3000 ; quick swipe right off onto the dock. Changed X40 to X120 because,... absolute.
And I got rid of the F240.
calibrate_z is dropping off the probe now.
So next is clean the rails and regrease them. Retighten the necessary bolts.
Then bed mesh and work on print start macros right?
So I went on the raspberry pi forum and they helped me get the raspberry pi connected without internet.
This is what worked for me:
I shut off ICS, internet connection sharing in: settings> scroll down below Advanced network settings>network sharing center> top left, change adapter settings>right-click wifi> sharing tab at the top: make sure the boxes aren't checked.
In the wifi TCP/IPv4 settings> properties there is nothing, no addresses.
In settings> below advanced network settings at the bottom of the page, change adapter options>right click ethernet>select TCP/IPv4> select properties>entered 192.168.1.30 for IP address> 255.255.0.0 for subnet mask
Only option was to Use the following DNS server addresses, it wouldn't allow them to be addressed automatically.
In the DNS boxes I have 8.8.8.8 and 8.8.4.4. OK and close.
I did run angry IP scanner to make sure nothing else was playing in the 192.168.1. area.
Logged into putty.
Code: Select all
sudo nmtui
copied that here
shift/insert to paste it into putty terminal window.
Since it was entered once, now the up arrow makes it appear.
Hit enter on edit a connection>again on Ethernet wired connection> scrolled down to IPv4 configuration addresses
and entered 192.168.1.30> scroll to the bottom right to hit enter OK, scroll down to back hit enter>scroll down to quit and hit enter.
Coming back later the pi changed that address to 192.168.1.254/24
Then I shut everything off, waited and turned the laptop and pi back on.
I shut off internet on the laptop and hit the raspberrypi.local and it connected.
I used a better print start macro.
First problem with that is I needed to add [exclude object] to the printer.cfg.
I added it near the top under my [include] stuff.
Then I got the all-too-common error of "out of range"? I think it was.
In Z stepper settings I had to set it below 0.
Which didn't seem safe but it worked.
position_min: -2
Next problem was solved by adding:
[firmware_retraction]
retract_length: 0.8
retract_speed: 60
unretract_extra_length: 0
unretract_speed: 60
near the bottom of the Extruder section, still in printer.cfg
Had to put klicky in the PRINT_START
Not sure how to post code on here.
But here's my print start:
# A better print_start macro for v2/trident
## *** THINGS TO UNCOMMENT: ***
## Bed mesh (2 lines at 2 locations)
## Nevermore (if you have one)
## Z_TILT_ADJUST (For Trident only)
## QUAD_GANTRY_LEVEL (For V2.4 only)
## Beacon Contact logic (if you have one. 4 lines at 4 locations)
[gcode_macro PRINT_START]
gcode:
# This part fetches data from your slicer. Such as bed, extruder, and chamber temps and size of your printer.
{% set target_bed = params.BED|int %}
{% set target_extruder = params.HOTEND|int %}
{% set target_chamber = params.CHAMBER|default("45")|int %}
{% set target_chamber_minimal = params.CHAMBER_MINIMAL|default("0")|int %}
{% set target_chamber_wait = [target_chamber, target_chamber_minimal]|select(">", 0)|min|default(0) %}
{% set x_wait = printer.toolhead.axis_maximum.x|float / 2 %}
{% set y_wait = printer.toolhead.axis_maximum.y|float / 2 %}
## Uncomment for Beacon Contact (1 of 4 for beacon contact)
#SET_GCODE_OFFSET Z=0 # Set offset to 0
# Clear any lingering pause states
CLEAR_PAUSE
# Home the printer, set absolute positioning and update the Stealthburner LEDs.
STATUS_HOMING # Set LEDs to homing-mode
G28 # Full home (XYZ)
G90 # Absolute position
## Uncomment for bed mesh (1 of 2 for bed mesh)
BED_MESH_CLEAR # Clear old saved bed mesh (if any)
# Check if the bed temp is higher than 90c - if so then trigger a heatsoak.
{% if params.BED|int > 90 %}
SET_DISPLAY_TEXT MSG="Bed: {target_bed}c" # Display info on display
STATUS_HEATING # Set LEDs to heating-mode
M106 S255 # Turn on the PT-fan
## Uncomment if you have a Nevermore.
#SET_PIN PIN=nevermore VALUE=1 # Turn on the nevermore
G1 X{x_wait} Y{y_wait} Z15 F9000 # Go to center of the bed
M190 S{target_bed} # Set the target temp for the bed
SET_DISPLAY_TEXT MSG="Heatsoak: {target_chamber_wait}c" # Display info on display
TEMPERATURE_WAIT SENSOR="temperature_sensor chamber" MINIMUM={target_chamber_wait} # Waits for chamber temp
# If the bed temp is not over 90c, then skip the heatsoak and just heat up to set temp with a 5 min soak
{% else %}
SET_DISPLAY_TEXT MSG="Soak for 5 min" # Display info on display
G4 P1000 # Wait 5 min for the bedtemp to stabilize
{% endif %}
# Heat hotend to 150c. This helps with getting a correct Z-home.
SET_DISPLAY_TEXT MSG="Hotend: 150c" # Display info on display
M109 S150 # Heat hotend to 150c
## Uncomment for V2.4 (Quad gantry level AKA QGL)
SET_DISPLAY_TEXT MSG="Leveling" # Display info on display
STATUS_LEVELING # Set LEDs to leveling-mode
QUAD_GANTRY_LEVEL # Level the printer via QGL
G28 Z # Home Z again after QGL
## Uncomment for bed mesh (2 of 2 for bed mesh)
SET_DISPLAY_TEXT MSG="Bed mesh" # Display info on display
STATUS_MESHING # Set LEDs to bed mesh-mode
BED_MESH_CALIBRATE # Start the bed mesh (add ADAPTIVE=1) for adaptive bed mesh
## Uncomment for Klicky auto-z
SET_DISPLAY_TEXT MSG="Z-offset" # Displays info
CALIBRATE_Z # Calibrates Z-offset with klicky
# Heat up the hotend up to target via data from slicer
SET_DISPLAY_TEXT MSG="Hotend: {target_extruder}c" # Display info on display
M107 # Turn off partcooling fan
M109 S{target_extruder} # Heat the hotend to set temp
# Get ready to print by doing a primeline and updating the LEDs
SET_DISPLAY_TEXT MSG="Printer goes brr" # Display info on display
STATUS_PRINTING # Set LEDs to printing-mode
G0 X{x_wait - 50} Y175 F10000 # Go to starting point
G0 Z.4 # Raise Z to 0.4
G91 # Incremental positioning
G1 X100 E20 F1000 # Primeline
Auto z is working great.
I can run it then bring the nozzle down to .076mm with the controls in mainsail and the .076mm (.003") feeler gauge slides snuggly under it.
Couldn't figure out how to actually print for a while.
All the videos and tutorials basically just say "then print".
In the SuperSlicer "Gcode preview" tab, at the lower right there is an "Export G-code" button
and just to the right of that is a G>.
A window pops up that allows "Upload and Print"
Click that and it all starts running through the routine.
I tried to print Ellis's First layer squish square from here.
One little patch in the center was the goal.
(First_Layer_Patch-0.25mm.stl
It prints kind of, but not really.
It prints a layer so thin it's basically painted on, thin as spray paint.
Using PLA at 202C.
It has the nozzle so close to the bed at .25mm that it won't let the plastic flow, the extruder is clicking.
Not sure what I'm doing wrong. A quarter of a mm does sound pretty thin.
That's what I put in the slicer.
Still Fun/exciting to watch it go through all the steps.
For most of you I'm sure that excitement has worn off.
Nervously waiting for the point where it actually pushes out some plastic. With my finger on the emergency stop.
It looked like it was dragging across the plate, it was riding so low.
Thought I scratched it, but it's just leaving a thin almost imperceivable trail of plastic.
Like some dog dragging it's butt across the carpet.
So I pushed out my first plastic but haven't really even calibrated it yet.
Do you folks use the SuperSlicer calibration stuff or Ellis's?
I'll work toward posting a video.
Any suggestions appreciated.
Moving right along.
I printed the worst temperature tower ever.
Haven't seen any suggestion of how fast to print it, looks like it's still soft when the next layer gets printed on top of it.
I changed the time between layers to slow it down.
Main problem was the part cooling fan wasn't running.
Using SuperSlicer,I had to change default fan speed in filament> cooling to 100% and max fan speed to 100%.
Now it cools nice and I made the best temperature tower ever.
Low cooling made the clicky clack door latch fall over.
Caught it before it made too much spaghetti.
Working on side panel latches for quick removal.
Haven't done input shaping yet.
I made 4 latches last night, or tried to. Stepper driver was getting hot. so ended it at 3 by using exclude object.
Time to make some skirts with fans to cool it off.
I want to make the PiPlate so I have access to the Pi ports.
Having a hard time figuring out where it mounts.
Looks like it mounts on the left front? My Pi is near the right front. Is there a way to easily make it fit the front right area near the motor?
