Finally, after getting nearly all clips of the chain back in place, I pluggd it in and no fuses were breaking
After wireing i decided to also place a aluminium shhet betwen the heated bed and the bottom plate to redirect some heat back up to the plate and later the chamber.
Of course that is not the first print on the photo. Took some configuration and tuning, but I was surprised how fast it generated clean prints. I was expecting initial problems in the motion system, since it was the first time I build something like that.
Therefore, many thanks to everyone that contributed to the manual, documentation, invented and refined the build itself!
The first issue I got was, that the latch of the extruder didn't stayed close. But that I fixed with putting a heat shrink tubing (yellow on the photo, without shrinking) around the bolt. Now it stays perfectly closed.
Then the grat moment, the very first print after calibrating the extruder.
Temperature was totally too hot, but I was so stuned and proud that the printer actually produced anything that looked something like the file it got xD After the first adjustements in the slicer the right bar was printed. Dimensianlly acurate! What an amazing feeling.
Now lets try something more difficult:
Alright... The first mod I will build will be a filament runnout sensor...
Let's try again:
Adjusted the sclicer settings a bit more and switched from Cura tu SuperSlicer.
Time to tune the machine a bit more with the well known and referenced
https://ellis3dp.com/Print-Tuning-Guide/
And some failures and tests later, the printer is finally printing the missing parts itself
Next steps will be know printing the skirt and adding the fans and display. Then the filament runout sensor.
