If I use the configurator to get a BOM for a custom size printer, the Z linear rails are shorter than the vertical extrusions by roughly 30mm. If I order standard length linear rails, what's the range of length I can use when compared to the Z (vertical) extrusions?
I'm thinking the linear rail length can be between interior frame Z height, and maybe 30mm shorter than that. If they're too short the gantry will come off at the top. Or you just limit the Z upper limit so that doesn't happen.
Maybe I just answered my own question!!!
