Mxbrnr
Aug 7, 2023,
Starting my build log for the V2.4r2 350 that I have just started self-sourcing over the weekend. Choosing self-source because I did not like easily half of the included parts that came with any of the kits I have seen (Including Formbot, LDO, and Siboor), so I'm not going to spend the money for a box half full of parts that I would swap out and toss in the trash from the very beginning. Happy to receive any comments/suggestions about mods, upgrades, add-ons, tips for the build.
Currently in the process of tuning my V0.2 (A.K.A "Darth Voron") to start printing the functional parts. Color scheme will be that of Disney's Buzz Lightyear , hence the name "Voron BuzzLight."
Here is the planned configuration:
Frame:
Frame:
- 350 Cube Kit in Gloss White (+50mm extra Z-height for cable/tube clearance)... https://dllpdf.com/voron-2.4-frame
Lightweight CNC Aluminum or Carbon Fiber X-Gantry- X/Y Gantry Titanium Backers... https://west3d.com/products/titanium-backers-for-voron-2-4-trident-3-pack?variant=42064409624788
- Armchair Engineering Xol-Toolhead... https://github.com/Armchair-Engineering/Xol-Toolhead
- Annex Engineering Sherpa Mini Extruder... https://github.com/Annex-Engineering/Sherpa_Mini-Extruder
- BMG RIDGA... https://kb-3d.com/store/spare-parts...-drive-gear-assembly-ridga-7350011414734.html
Phaetus Rapido 2 UHF PT1000 Hot End...https://west3d.com/products/rapido-hot-end-high-flow-tl-phaetus?variant=43817479274708- Haldis Red Lizard K1 Pro HF hot end... https://a.co/d/jllYVnm
- BTT EBB36 CAN Bus Umbilical... https://kb-3d.com/store/printer-spe...dent-internal-configurator-1681232307779.html
- Beacon (IDM/Cartographer) Z-Probe with KAMP
- BTT Octopus MAX EZ... https://west3d.com/products/btt-oct...er-control-system?_pos=1&_sid=67cca0f67&_ss=r
- BTT EZ5160 Drivers... https://west3d.com/products/btt-ez5160-driver?_pos=1&_sid=2c0fea475&_ss=r
- BTT/Klipper Pi... https://west3d.com/products/btt-bigtreetech-pi-computing-core-board?_pos=1&_sid=873ddf654&_ss=r
- BTT/Klipper Pi CAN adapter
BTT U2C CAN Bus Board...https://kb-3d.com/store/controllers-displays-drivers/788-bigtreetech-u2c-v21-usb-to-can-bus-adapter-pcb-1674401555972.html- Moons High Temp Motors for all positions
- Filament Runout Switch
- MIC6 Aluminum Bed... https://west3d.com/products/voron-2-4-build-mic6-aluminum-build-plate?variant=41126171279528
- KB3D MinMax Bed Heater... https://kb-3d.com/store/voron/797-k...er-for-voron-v24-trident-multiple-styles.html
- Inverted Z-Chain... https://www.printables.com/model/445298-inverted-z-chain-for-voron
- USB Webcam... https://mods.vorondesign.com/detail/RYpQW53mtem8Nj1JKqiSQ
- Provok3D ADXL345 Nozzle-Mount Input Shaper... https://west3d.com/products/adxl-no...ut-shaping?_pos=1&_psq=adxl+nozz&_ss=e&_v=1.0
- Beefy Front and Z-Idlers (Clee's BFI & BZI)... https://github.com/clee/VoronBFI
- Sensorless X-Y Endstops... refer to official Klipper documentation
- Nevermore Micro Air Filter... https://github.com/nevermore3d/Nevermore_Micro
Bed Fans...https://mods.vorondesign.com/detail/28xgztUufAtAfV4XUL5l4w- GE5C Z-Carriage Mount... https://mods.vorondesign.com/detail/eB5T2RNQcYI4o6cilhpXEg
- Front Doors Removable Wide-Opening Hinges... https://mods.vorondesign.com/detail/WqhhKrXksAZ4omhHS1RY4Q
- Side/Top Panel Snap Latches... https://mods.vorondesign.com/detail/9Rdnf5vD2oaJLmR7BpAuQ
- Decontaminator Purge Bucket & Nozzle Scrubber... https://mods.vorondesign.com/detail/eiGz71BOprk2GapXbQVgA
- Case LED Light Strips... https://www.teamfdm.com/files/file/447-led-clipping-rails-for-250-300-and-350-frames/
- Umbilical/Bowden Tube Guide
- Case Carrying Handles... https://mods.vorondesign.com/detail/xa84lhUN5aMX4nmfZquaQ
- Front Skirt Power Switch
- Enclosure Temp Thermistor
Car Hood Style Heated Bed Hinge with Flipped Electronics Bay...https://github.com/VoronDesign/VoronUsers/tree/master/printer_mods/xbst_/Bed_Hinge- Extrusion Slot Covers... https://mods.vorondesign.com/detail/ZKJgu7OwMNB1xAKRrYSYeg
- Filament cleaner... https://mods.vorondesign.com/?search=lj-scrubby
