Hello to all Voron enthusiasts,
I’ve slowly started the Voron 2.4 build, and I’m not entirely sure where to apply Shaft Retaining Compound (Loctite 641), which is on the list of recommended tools for the build (https://vorondesign.com/sourcing_guide, Voron Tools Tab).
The Build Manual doesn’t mention it anywhere, only thread lockers, which are a different type of chemical (I’m using Loctite 222 because the screws are small).
I assume 641 is meant for securing bearings, pulleys, etc., to the shafts, but as I said, the Voron assembly manual doesn’t mention it anywhere.
Does anyone have experience with where to use it and where to avoid it? 641 is removable, but only after heating to 250°C, so I’d prefer to avoid any mistakes.
Thanks for the advice!
