sanketss84
Hi All,
Building a Voron Trident or any Voron for that matter in India. Its not as easy as placing an order for a kit and you get a box full of components delivered at your door step with everything nicely labelled and you just have to assemble it. We do not have ready availability of kit in India as of Feb 2024 while I am writing this.
Yes we can import one but the money I would be paying as import duties can be equal to getting another voron printer for that same amount. So, self sourcing is the only option.
I have been extensively planning and gradually buying hardware for my Trident 300 build and I wanted to document each and every nuances, decisions and thought process I took for my build so that if any one else decided to build one he/she can have a reference.
With that I will start by sharing everything related to my build here.
This will be an extremely detailed log . . . .
Legend
Legend
- documented
- pending documentation, completed at my end
- pending
- Why am I building a voron and how did I came up on this decision ? link
- Am I aware of other open source 3d printer projects ? link
- Which Voron ? link
- Why I felt strongly about Voron Trident ? link
- What size Trident am I building and Why ? link
- Planning Phase link
- The Blue Print, The Tool Head and Voron Mods link
- Part Selection : The Frame link
- Part Selection : Linear Rails link
- Part Selection : Nema 17 Stepper Motors link
- Part Selection : Power Supply link
- Part Selection : Controller Board link
- Part Selection : Stepper Motor Drivers link
- Part Selection : Bed , Heater and Build Plate link
- Part Selection : Can Bus Adapter + Tool Head Can Bus PCB link
- Part Selection : Various Wires and Connectors link
- Part Selection : Build Tools link
- Part Selection : Lubricants link
- Part Selection : Tapes link
- Part Selection : Extruder, Hotend, Fans, Toohead PCB and Tool head design link
- Print voron trident build parts myself or PIF ? link
- Why did I decided to print parts myself and challenges faced ? link
- The Build : Frame
- The Build : AB Drive and Idlers
- The Build : Y Axis
- The Build : Z Axis
- The Build : X Axis
- The Build : Belts
- The Build : Toolhead
- The Build : Wiring Prep
- The Build : Electronics
- The Build : Controller Prep
- pi setup with mainsail os
- compile klipper for controller board
- can bus setup for toolhead
- printer.cfg
- The Build : Skirts
- The Build : Print Bed (doing this at the very end )
- Pre Power Up checks (nero3d)
- Ellis print tuning
- Setting up slicer for PLA
- Testing PLA for few days without panels installed
- Setting up slicer for ABS
- Testing ABS for few days with panels installed
- Beefy Idlers
- Dragon Burner
- Orbiter V2 extruder mount
- Phaetus Dragon Standard Hotend mount
- Bambulab V2 Hotend mount (alt hotend)
- Klicky Probe mount
- Beacon Mount (alt bed mesh probe)
- Klicky Probe
- The Filter (singles)
- Annex Engineering Panel Clips
- Top Mounted Spool Holder
- Led Bar Clip
