A month later and I have just revisited the build log. I had hoped to get it up and running in November, but that was completely upset by a couple of simple frustrations.
I couldn't get past the homing.
Sounds stupid I know, but I kept having issues with seemingly tiny things:
1. First of all the X/Y belts. They were loose, and the homing seemed to make them worse. An examination into this revealed a simple and overlooked part of the "TAP" upgrade (yes that same thing coming back to haunt me).
can anyone spot anything missing in the highlighted red circle? No? Well, it turns out that there is a small printed piece that is used to clamp the belts.
Should be obvious right? It escaped me. So much so that I ended up ordering a CNC TAP from Mellow. That kit came with a little metal piece to clamp the belts.
Great. I could now tighten the belts and get to homing.
Erk. No. On to the new issue:
2. The CNC kit didn't have the right physical shape to hit the microswitch endstop.
The solution to this was found within the community. Whoever Stadi_602547 is, I thank you very much! I hope it is alright to link the solution here:
www.printables.com
I did end up printing this in PLA (I don't trust the Ender for ABS/ASA), and will be scheduled as one of the first parts to print once the enclosure is on.
Great! New TAP installed, X is homing fine, should be smooth sailing from here.
Nope
3. The new TAP feels like it works great, but is not triggering. All the physical stuff checks out, must be wiring or software.
After uncounted reconfigurations of the software, multiple wiring changes, I did resolve this.
It turns out that despite my thinking that TAP should count as a "probe" and therefore be plugged into the Octopus' "probe" pin PB7.
Save yourself some hassle and don't do that. Just connect it up to a regular old endstop pin (stop_7 in my case - PG15)
That should be it, right? 3 little niggles dealt with and on to printing?
Sadly no. I will leave the next one for a new post though. This is getting a bit long.
